Page 153 of 190 FirstFirst ... 53103143151152153154155163 ... LastLast
Results 1,521 to 1,530 of 1896
Thread: Sam's build thread
  1. #1521
    nsw
    Thanks for the offer buddy. When it gets closer I'll find out how late we can practice on the Saturday to see if I'd be able to make it for anything meaningful.
  2. #1522
    nsw
    Just bought one of these. Golf 6 GTI turbo one step closer to fitment.
    CB Auto. K04-064 TFSI to 1.8t Adaptor plate
  3. #1523
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by sambb View Post
    Did you weigh up the option of getting a hybrid turbo which would be a direct fit to your car?
    Hybrid turbochargers and more | Beachbuggyturbo
    I must admit I haven't read the latest on your thread, you might explain why you are going to way already with the adapter. Possibly cost.
  4. #1524
    nsw
    I did consider a ko3 plug n play but the reality is the good ones are very expensive eg TTE and BBT. At the end of the day they are putting big wheels in tiny housings fed by a really restricted mani that due to the extreme heat burns gaskets , loosens bolts in the turbo to mani connection etc. once boosted up too they come on like light switches , have mountains of torque when you don't want it and I've heard of surge issues too. So it'd be the convenient swap but not really what I'm after.
    The golf 5/6 ko3/ihi have better designed exhaust runners, no turbo to mani connection, apparently easy k04-023 performance and more cos they'll allow you to get more timing into your engine, bigger housings. So same power for less heat/egt's whilst not as pushed. Big thing though is with the adapter in place, these turbos' big brother the ko4-064 ( golf 5 Pirelli/ golf 6 R) is then a direct bolt up. Inlet piping is dead easy , boosted piping is almost stock routing. Yes it'll need a dump made up to blend with my existing piping though.
    So basically cos you can get these turbos very cheap the cost is really in the adapter and the dump and tune which puts it on par with a ko4-023 build and ahead of a garret conversion as turbo cost is lower. Garret conversions also need custom piping, , custom oil/water lines (my conversion only needs a cut and shut on the oil drain) and most likely a single pass IC too so in general the tfsi conversion came out ahead cost wise compared to a garret conversion for me.
    And if I ever get my poop together and get rods into one of my engines i can easily swap over to the ko4-064 (2860 equiv) for some real grunt.
  5. #1525
    Jan 2011
    Gold Coast, QLD
    That's interesting, looking forward to seeing the install.
  6. #1526
    nsw
    Well if I can pin my current oil useage on my existing turbo then it'll be on very soon. If the oil usage is something more sinister though then it'll be a fair bit longer.
  7. #1527
    Jun 2017
    Newcastle, NSW
    So... A3 layout for Ringwood State round. Seems a lot of regulars are unhappy as they can't chase the records for their class.
  8. #1528
    nsw
    So what's A3 then - you redo the bottom loop or redo the top half? Got a vid of it?
  9. #1529
    nsw
    Had a heart attack the other day and thought my front main seal was leaking. I was getting an oily residue on the radiator cowl and thought that it was leaking oil onto the belts and then the belts throwing it there. Turned out that the A/C was weeping from one of the pipes. So that was the excuse I needed to go all racecar and take out the pump, pipes, heat exchanger etc etc. 5 kg lighter in the front now! and set to bake in western sydney traffic in summer but I feel racey for now!! While I was at it I finished off the oil coolers ducting so that now it sits fully inside an aluminium duct without air able to spill away from the core face at all. The car ran SMSP south circuit and the oil never got above 118 degrees but that should only get better now.Sam's build thread-img_8789-jpg
    With the A/C heat exchanger removed, the SEAT sport IC sits a good 20-25mm free of the radiator. I've read that that's a bad thing for radiator flow and that if I cant get an A2A IC butted right up against the radiator core then I need to seal the perimeter of the IC against the radiator face as a next best option. I may end up having this IC for a while now given that my future turbo plans lend themselves to this config so want to make it as efficient as possible so any advice on that welcome?
  10. #1530
    Jun 2017
    Newcastle, NSW
    A3 is a pretty cool layout, basically twice around.
    in car video of me running A3
    Sam's build thread-ringwood-track-a3-jpg
    Tracks and Records - MG Car Club Newcastle
    Last edited by metalhead; 18-07-2019 at 09:45 PM. Reason: I give up trying to embed the video!
