Page 148 of 190 FirstFirst ... 4898138146147148149150158 ... LastLast
Results 1,471 to 1,480 of 1896
Thread: Sam's build thread
  1. #1471
    nsw
    ok sweet. Linear 8kg/mm fronts from MCA it is then. thx
  2. #1472
    Jan 2009
    Quote Originally Posted by sambb View Post
    I think you've probably seen my vids of the Ringwood Hillclimb circuit which has corners as tight as yours. The main thing that helped there was as much rear roll stiffness as possible ie springs or bar. You could also run the rear a tad higher to get its roll centre up and pump up the rears so it'll rotate a bit more. Should help you in being able to get on the power earlier.
    Thanks Sam. Yeah, my only choice from here is stiffer rear springs as the bar is hard and the rear is already quite lifted. In reality, it was rotating quite nicely on the most part. On reflection, probably a bit more pressure in the rear tyres wouldn't go astray (I had dropped them down to 30psi hot), but I otherwise had a driveable amount of oversteer/rotation.
    I think I've still got the data you'd sent me re the H&R's, might have to look into rear springs.
    Daily: 2010 VW Jetta Highline
  3. #1473
    nsw
    I may have a pair of 150mm 6kg/mm springs soon, back off a friend. They have the standard coilover I.D of 60mm(??) so if that length works with your adjustent range I'll send them up for you to try if you want. They are 335lb in but with motion/leverage ratios of the beam factored in they are 220lb in at the rear wheel so a decent jump up.
  4. #1474
    nsw
    DTM's 600+hp 4cyl turbo replacement of the V8. Warning... pornography within. Supercars' future?
    YouTube
    YouTube
  5. #1475
    nsw
    Alright here's the vid of Dub Nats 2019 at SMSP south circuit. First go on an editor and didn't realsie till the end that it had a bloody watermark all over it. Hopefully you can see the wheel work - most fun bits are the way it was moving around under brakes at the end of the back straight. The car in front was a Golf Mk7 R, no idea what state of tune etc but we had a good little run together once we both got on with it:
    here's the vid: YouTube you'll need to go 30 secs in before anything happens
    and be gentle.... I know I drove really scruffy throughout
  6. #1476
    Apr 2015
    Quick comments, small stuff, nothing major, no need for self deprecation, you were way better than most;
    Later apexes on almost every corner, make the straights longer.
    Steering wheel should be straightening on approaching the apex, not still turning.
    Apply power as soon as you start straightening up the steering (more power as lock decreases), more power means less understeer.
    You should be at full throttle at the apex for most corners.
    Turn 1 you need to be much more hungry on the bread roll strip, over it, inside it, use it to hold the line, it will help with turn 2 which is currently being compromised and thus affecting speed up the hill. Same with ripple strips, if there is flat concrete inside of them use it.
    I need to look at in some more on the big screen to see what is happening suspension wise.
    Gary
  7. #1477
    nsw
    You're dead right. Having watched it back properly myself now I'm constantly thinking 'stop turning in so early'. Sam's build thread-maps-gpsouth-1024x724-jpgThe only place where it felt quicker to be turning in early was the left hander before heading down the hill towards the hairpin but I can see that overall I was doing what you said.
    I cant find a circuit map for South circuit without the main circuit turn numbers on it. So based on the one above, you're saying early turn in at T15c was hurting T5. I was also a serial turn in early fiend at T6 which was hurting T7. Once I got off 11, the next part through to T14 felt good but the entry to T15a was troubling me and I think responsible for everything leading through to T5 - If I braked as late as I felt I should be the car was sliding around a lot, if I was more conservative under brakes I found because I had more time maybe that I was too eager and was turning in early. The track was very dirty down there from lots of off etc and it never really improved throughout the day and neither did my confidence to turn it in while it was stepping out too much. Bugger.
    Maybe I'll hold off on springs and just drive it better next time. I measured my front cambers last night and the front right was 2'55'' so I should have had a bit more on that side too which would have hurt me a bit too.
  8. #1478
    Jan 2009
    Nice work Sam.
    Don't know if my video from last year is much better/any help as for comparing lines.
    Vbox Uk website has a great e-book "https://www.vboxmotorsport.co.uk/index.php/en/applications/free-ebook-race-drivers-tips" which I review before track events. Given SMSP South circuit is tight, there's corners to sacrifice on just to get a clean run at the next corner. I find S's post turn 1 to be all late apex, the hairpin to be late so you get straight on throttle, along with back up the hill, etc. It's a different matter as to whether I actually achieved that and landed anywhere near an apex You might enjoy the reading.
    By way of video editing software, there's Davinci Video editing which is free. I don't think the water mark is anywhere near the size of the software you've used. I've not used Davinci myself, but have heard it's very powerful and free.
  9. #1479
    Apr 2015
    Using that map, some things to try;
    T6, get over the other side of the bread roll it will make T7, T8 and T9 much faster corners.
    T10, hungry on the bread roll, straighten the corner out as much as possible.
    T11 , late apex, slower in faster out, get on the throttle before the apex, don't run wide on the exit as it ruins T12 which is a more important corner.
    T12, same, sacrifice the entry for the exit, lengthen the straight up the hill.
    T15a is a slow corner so the best you can do is make the exit as fast as possible.
    T15c even more so, as it influences the speed all the way to T6.
    Gary
  10. #1480
    Oct 2017
    Wodonga, Vic
    interesting stuff... there's a sprint at my local track in a few weeks, I think I'll take a video of it and see if you guys can help me along. I have some videos from last year but the car has changed a lot so I doubt they're a lot of value
