Just tested the fan control module through the radiator fan switch plug. The low speed is coming on for the fans but not the high speed. So probably a shagged high speed relay. I've dug out the one I took off the old car and will throw that in. Once I get that sorted i'll have to re access whats going on with water temps cos if high speed fan control wasnt working in traffic that'd have been having a big effect.
I was chatting with SimonKK the other day and when throwing ideas around we thought that you could put the heat exchanger back in yet run it with an oil cooler too. In the water line that feeds the exchanger its hot water, you could run an in line tap. So on the street have the tap open so it works like OE but for the track close the tap so that water temp cant influence the oil temps and the oil then runs solely off the oil cooler effect independent of what the coolant temp is doing. A switchable way of having best of both worlds - Sound do able?
Yeah I threw in a spare (2nd hand) PCV which tested ok. I will ditch the plastic membrane ones for something a bit more solid when I get around to it, but yep the PCV valve did look ok and the PRV tested ok too.
