Round 3 of the NSW hillclimbs tomorrow at Canberra. My car had been pulling a bit of timing on its bosch ev14 550cc injector tune in the summers heat so I decided I'd get some water injection happening for this round to try to combat heat soak.
So basically I used a punch set at work to knock a hole in the inlet hose for the bung fitting that houses an Aquamist 50cc/min @ 80psi nozzle. The water reservoir is on the passenger side of the boot in that little void with the fire extinguisher mount? if that's what it is. I swapped out the rubber strap for a proper tie down strap and the plastic container which holds the distilled water is rock solid and holds plenty for such a tiny nozzle. The pump is mounted in the wheel well and fits neatly in there without fouling on the tyre. The power to the pump is run in cabin but the water lines are run through the chassis rail that houses the fuel lines. It uses a bulkhead fitting to get the water through into the wheel well and in the engine bay pops up where the fuel lines do. The water is controlled using an LPG liquid lock off solenoid and is triggered by an adjustable pressure switch for 11psi. The nozzle position tried to take into account the way that the airflow will wrap around the inlet pipe and hopefully lines up the throttle body for a nice straight shot into the plenum.
From speaking to my tuner, the way the bosch ME7.5 timing/knock control works it is always trying to run a threshold amount of timing. It'll look at inlet air temps, load conditions, engine temps, EGT calcs etc and work out from that what it should be doing with timing, even relative to the maps that are in there. Apparently 1.8T tuners have found that spraying water pre throttle body drops the air temps as seen by the inlet temp sensor at the throttle body which then makes the system feel more secure to push the envelope with timing. I ran the exact same system on my last car and could do a 3rd gear pull with up to 4.5 degrees timing pull all through the log and then switch water injection on and repeat and literally find no timing pull at all. I could add up to 2 lemmiwinks holistic timing increment (2 X 0.75 degrees) for the same timing pull in the logs, so it does work - not only at convincing the ECU to run more advance, but by making that possible without timing pull because of the anti knock properties of plain water if its getting into the combustion chamber still as droplets.
Other improvement for the car/me is an RPM 6 point harness. I got the crotch strap all set up last night and it felt seriously safe. I must say the 3 inch shoulder straps on the 4 pointer that Metalhead lent me were far more comfortable than the 2in straps (intended for a HANS device) on this 6 pointer - they really can be felt over your collar bones, but I'll probably sort a HANS device soon enough so I can live with that.
So all ready to go tomorrow. Its going to be 25 degrees and sunny so should be a good day to give the car a bit of a caning. Bummed I didn't get down to do practice today as I haven't been there for 2 years, but I'm sure it'll all come back to me during the red mist first run.
