06-02-2019, 10:30 AM
#1311
I just bought a second set of standard rims. Was intending to put on Federal RSRs for hillclimb, but it seems that the AO50s are much better, so thinking of them in 205/50/16.
How do you find them for durability in the medium compound?
06-02-2019, 11:51 AM
#1312
For the track the A050 are hands down the better tyre but they are a track only tyre whereas the federal RSR/Yokohama AD08R/Hankook RS3 street high performance tyres can do street and sprint.
A050's aren't cheap new so if you really want them to last you might be better off buying mediums. If you were to buy softs theyd be undoubtedly quicker for hillclimbs and may last pretty well too but as soon as you use them in a sprint eg a tarmac rallysprint they will get chopped up pretty quick. I used mediums exclusively in my first 1/1/2 years of hillclimbing and they still grip pretty damn well, way better than my AD08R's had (which are very very good tyres in there own right). I then started using some softs at different tracks as well. The advantage of mediums is that at least you can hit the track too whereas you'll torch softs. When I went to Wakefield I was on 205 medium A050's that were 3/1/2 years old and ripped to bits. It was the first time I had ever been on a circuit in my life and I managed a mid 1:10 so they really are a pretty confidence inspiring tyre and worth it. I'm moving away from softs on the front and will be running 215/50/15 medium fronts this year for everything (circuit/hillclimb/rallysprint) - once I cycle whats left of my softs and 205 mediums through the rear then I'll go to 215 mediums at the back too. Cant afford two compounds even though hillclimbs are my favoured thing. Those old tyres that I set that time on in jan 2018 I've been using everywhere since the start of 2016 doing 12 events a year and they were thoroughly second hand when I got them. They are shagged yes but will still outgrip an RSR I'd say and still hang in there provided you are careful with your pressures
Hopefully your rims are 7in wide and then I'd be looking at 225/45/16 which is a pretty commonly used size for A050 and you then run the risk of actually picking up a decent second hand set for a fraction of the price of new. From what I've been told the Dunlop Direzza DZ03G is a beast of a thing too but may not come up to temp quite as fast as an A050 will which is what you want if you are going to double duty a medium for hillclimbs as well as track.
06-02-2019, 11:58 AM
#1313
Great, thanks for the info. Definitely looking at hillclimb and track so will go with the mediums. I’ll be changing rims at the track so no worries with them being track only.
Pretty sure the stock rims are 6.5 so will have to go 205 50 16 rather than 225s I think.
06-02-2019, 12:03 PM
#1314
Me and another guy off here will be at the SDMA round of the State Hillclimb Championships this year in the road registered over 2.5L class. There's nothing to stop you entering even if you're not doing the whole series (happens a lot) so have a think about it. I'll be at Mt Panorama March 2 and 3 rd if you are happening past - if its after about 3pm when each days running is over I could probably take you for a little lap while its got its fast shoes on so you get an idea of the rubber.
http://hillclimbnsw.com/cal.pdf
06-02-2019, 12:06 PM
#1315
Yeah 205's would be the go on a 6.5in. Hankook do a Z221 R spec in that size you mentioned maybe?
06-02-2019, 01:39 PM
#1316
Cool, I’ll definitely be running the state round an SDMA so will see you there. Was planning on heading to Bathurst but it’s my daughters first birthday so might save the brownie points it would cost me for later in the year
06-02-2019, 02:02 PM
#1317
VW Transporter T4 2.5L TDI clutch and PP. I managed to break one of the little clips on the release bearing unit that hold it into the release fork so have another one of them on the way …..dumbass.
got the inside waist strap eye bolt in last night. You have to remove all the under body trays, the exhaust tunnel cross brace and bend the exhaust resonator heat shield out of the way. worth doing because there are some ribs in the tunnel which is good for strength but can interfere with the plate sitting flush. last two pics are of the plate on the side of the tunnel and how it looks with the heatshield for the exhaust back in place - lots of clearance. So I'm good for a 4 pointer now but I just got word that Scroth wont be doing 4 pointers in Australia anymore and I might struggle to find the harness I wanted. That leaves only the Takata. If that end s up being a struggle I may just have to mutilate the seat and go 6 point afterall. thinking thinking...
06-02-2019, 02:49 PM
#1318
Sam's build thread
What about Toyo R888Rs? They are pretty decently priced at the stock size TOYO 205/45R16 PROXES R888R TYRES SEMI SLICK TRACK 2054516 205-45-16
06-02-2019, 06:05 PM
#1319
I havent driven them but I've spoken to many who have changed from them to A050's including my best mate who tried them back to back against worn A050's on an identical set of rims (back to back seesions) and the consensus seems to be that R888 aren't in the same league compared to A050. My mate video'd himself driving on the R888 and you could hear the tyre squeal and see the understeer almost everywhere around south circuit and he was like a full second quicker. They weren't any quicker than brand new AR1 Nankangs. He reckoned he could have gone as quick on his AD08R 'street semis' as the Toyo's. Again that just his word and the word of other people at the hillclimbs etc but I must say that I have noticed just about everyone is on either Hankook or Yoko R specs. Toyos, Nittos just don't seem to be on many cars any more.
06-02-2019, 06:06 PM
#1320
and people definitely say that the Toyos are slow to come up to temp compared to A050's which is a definite factor if you're on Yoko mediums in a hillclimb.
- You may not post replies
- You may not edit your posts
Forum Rules
