Page 126 of 190 FirstFirst ... 2676116124125126127128136176 ... LastLast
Results 1,251 to 1,260 of 1896
Thread: Sam's build thread
  1. #1251
    Oct 2017
    Wodonga, Vic
    nice... mind having another crack at the images Sam?
  2. #1252
    nsw
    Twin plate twin plate! No no I'll be at Bathurst no matter what, I mean I just wont commit to doing the new box before hand unless I'm certain it wont potentially compromise me going.
  3. #1253
    nsw
    bugger they came up ok on my pc at home but now seem to have been rejected. yeah I'll have another go.
    I'm picking up the crown wheel and pinion this arvo so fingers crossed the diff fits into the other. If so I can go ahead and button all that up so its one less thing for the gearbox guy to do.
  4. #1254
    nsw
    Sam's build thread-img_7766-jpgSam's build thread-img_7767-jpgSam's build thread-img_7768-jpgSam's build thread-img_7769-jpg
    Brand new crown wheel and pimion 61/18 = 3.4:1 more or less.
    I dummy fitted the crown wheel to the LSD housing to make sure they were both 114mm and they were. Turns out that the crown wheel doesn't actually have a chamfer and stepped edge on it. My 113mm crown wheel could have just been passed through and taken out to 114mm without any tricky profiles being cut. I was quoted 200 bucks for that work, so anyone who wants to go down this path there is no major need to buy a new final drive if you have a 113mm crown wheel and your diff is 114mm - your is totally machinable for cheaper. But I like the idea now of the longer final drive and it'll be nice to know the box has some factory new parts in there too.
    p.s I don't even know if the crown wheel is on the right way so don't copy my picks. I just wanted to check that the bolt lengths were correct with nothing pocking out the other side.
  5. #1255
    nsw
    Need diff to ring gear assembly help:
    I don't know what to torque them to. The bolts are an M11 X 1.0 hex head. The outside di of the threads is 10.85mm and the inside di is a bit over 10mm. In comparison an M12 coarse bolt at work had an inside pitch diameter of 10mm. So these Kaaz supplied bolts defo aren't M10 and they're not M12 either which is a bit odd.
    So in working out the max torque the problem is that:
    a) I don't know if they are 10.9 or 12.9's
    b) just try to find the torque spec for a metric fine M11. The torque spec for an M10 vs an M12 is hugely different and I don't think I can just split the difference between the two because the curves don't work that way as far as I remember.
    I've found some odd things on the net where people with this diff got in contact with Kaaz about the ring gear torque values because their instructions only mentioned torque specs for Hondas and Toyotas which had different numbers/sizes of bolts to the VW casing. I cant even refer to the VW specs 52 lb ft (70Nm) which is what Kaaz has said to do, a setting that sounds ridiculously low considering the factory setup was for either nuts onto push fit bolts or the diffs were riveted to the ring gears.
    The Kaaz setup on this diff is for the bolts to thread directly into the diff casing. I assume the casing is seriously hard steel, but like I said without knowing the grade of the kaaz bolts, being able to find the torque specs for such odd size bolts on the net, and Kaaz saying nothing on the issue, I'm a bit unsure as to how to proceed.
    I'm thinking just assume 12.9 grade and go for a torque setting on the low side of half way between M10 and M12. thoughts??!!
  6. #1256
    Oct 2017
    Wodonga, Vic
    might not help, but similar size bolts on a mini diff are done up to 60lb/ft, there are 6 of them - from memory they are 7/16" which is about 11mm
    your point b) look up the torque spec for 7/16 UNF (20 tpi) - my chart only goes up to grade 8 but it says 60lb/ft (lubed)
    your point a) the grade of the bolt whether 10 or 12 shouldn't make any difference. Going by this: Grades of Bolts then you should do them up to 60lb/ft and leave them
  7. #1257
    nsw
    All good now. Thanks mate. After lots of emails etc that fell on deaf ears I found that Kaaz have a facebook live thing and in the middle of the day today for some reason they responded. The figure was 65-70 ft lb which is 88-95Nm which puts them pretty squarely on the charts we have at work between 12 and 10mm. Don't know why the bolts have to be such a tricky size. So its all in the hands of the gearbox guy now. He'll strip the gears off the shafts (as the new pinion has to go in anyway) and inspect everything and then order whatever is needed before it all goes back together. I don't know if anyones done this diff into an 02R so I hope the casing and its inverted bolts have clearance etc
  8. #1258
    Oct 2017
    Wodonga, Vic
    where are you at with tyres Sam? what's the best bang for buck to be running?
    I'm all set up for my 15" wheels now, two have new-ish Nankang NS2 (205/55/15) and the other two have cracked and worn out Firestone road tyres, one of them with a nice piece of metal embedded in the tread... local tyre bloke told me new NS2s are $165 and only in 50 profile, I'm digging around for alternatives
    I can get the Federal RS-R control tyre for the Hyundai Excel series for $100, but they're 195 width so I'd probably look like I was going for the tyre stretch look. The 205/50/15 jump up to $155 for the RS-RR
  9. #1259
    nsw
    Is this for the street or track or both?
  10. #1260
    Oct 2017
    Wodonga, Vic
    mostly just for the circuit, same kind of use as you
    there's a set of used A050s on gumtree for $100, but they're in WA - haven't had a serious look at freight but I doubt it'll be cost effective
