Originally Posted by
sambb
Thanks Gary. That's the best run down of RWD handling I think I've ever read. Now I know that I didn't have a hope in hell of getting my Escort to handle all those years ago.
So the Nulon recommendation with the oil I just wanted to check that's applicable for something that is run on the street too ie is that an oil to be chucked in post break in or good to go straight away. My Kaaz is the Super Q version that has treated plates from the factory. Any reason the oil you suggested wouldn't work the same with those plates? I ask you because I know what Kaaz will say. And do you still need to run friction modifier if you run that oil or does its use become null and void.
We run it straight out of the bottle. We sent the KAAZ LSD specs to Nulon via their chemical engineer for him to recommended the oil for us to use. He already had the spec of the transaxle (it's a close ratio gearset but uses OE syncros) so he selected the oil that best suited both.
Gary
