![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
sambb
surprised a geared torsen style LSD is suggested in a RWD car. Is that because you can set them up with lots more front anti roll than a FWD and get the inside front in the air and concurently keep both rears firmly planted on the taarmac?
We certainly run more anti roll on the front of a RWD car than we do on the front of a FWD car, a lot more. Because we aren't concerned with adversely affecting inside wheel power down. As we have talked about a few times, we run positive rake (nose down) on a RWD car, plus a higher (than the front) rear roll centre. This increases the diagonal weight transfer (to the outside front wheel) and unloads the inside rear wheel, especially useful in a car with a spool. I run a slightly higher rear roll centre with a spool than I do with an LSD. We also run a much higher front spring rate than the rear, so the spring rate counteracts the swaybar rate to some extent (pushes down on the inside front wheel). But we also run a lot of rebound in the front dampers to reduce the corner exit understeer as the spool (or LSD) will make it push under acceleration. We also run about the same droop in the front suspension as in a FWD car for the same reason.
For me I find that a RWD car is tuned (for balance) mostly by adjusting the rear roll centre and the front swaybar. I rarely adjust the rear ride height or the rear swaybar and pretty much never adjust the front ride height.
Gary
