Originally Posted by
sambb
Starting to learn that rear toe (other than a rear bar) is king at determining the extent to which the car WANTS to turn.
Yes, it is
I haven't been back down to the aligner I use to verify the result
For DIY (warning this is going to take me longer to type and for your to read than it actually takes to do), you need 4 axle stands, 2 pieces of 25 mm box section alloy around 2 metres is plenty and some hat elastic (better than string). Mark the centre of the alloy box section, set the axle stands at the height of the centre of the wheels and put them just behind and in front, roughly in line with the headlights and tail lights. Place the box sections on the axle stands lining up the middle of them with the middle of the car. Measure between the box sections to make sure that they are parallel. Run the hat elastic down both sides of the car and tie each end to the box sections. Measure from the centre of the rear wheels to the hat elastic and equalise it by moving the hat elastic on the box section, do the same with the front wheels. Check by measuring the distance the hat elastic is in from the ends of the alloy box section, should be the same distance so that you have a right angled oblong (then mark the locations on the box sections for next time). Measure from the extremities (front and rear) of the wheel rim to the hat elastic. Duplicate on the other side, added together that's your total toe. Check it with your toe plates.
Warned you it would take longer to type/read than do.
Gary
