No wont be doing Mattara. Haven't done it since they moved from King Edward Park to Ringwood. Which day will you run on?
Sounds like we both had some issues at Huntley. I got in contact with the guy that did the tune discussing how the car was a bit slow to wind up when getting back on the power hard on 3rd after the esses. We've been sending tunes back and forth/loading/logging etc and now have a much more aggressive boost onset. I'd thought that maybe it was down on timing a bit as the loads increased with boost, as we'd done all the logging in very cool temps in August and thought maybe the timing had been a bit conservative, but it ended up being boost control. He'd initially actually done it that way because I'd asked for it. We'd talked about tempering the boost onset because the car used to wash wide under power so it was set up that way. It was great at South Circuit like that coming out of the hairpins so we left it, but I think how fast/steep Huntley is sort of exposed it a bit. So now I have a few boost ramps that I can use but will probably use the one that I had at Huntley if its wet and then the fastest spool for in the dry which'll be handy.
