Page 111 of 190 FirstFirst ... 1161101109110111112113121161 ... LastLast
Results 1,101 to 1,110 of 1896
Thread: Sam's build thread
  1. #1101
    Apr 2015
    Quote Originally Posted by sambb View Post
    Cool. I cant have a 1 piece seat permanently in the car cos its not street legal that way, but yeah I could have one to go in before events I suppose. If that was the case (read if I could get out of that without too many dollars) then I would go 6 point. I'll have to look into how much of a mission that would be - to do seat and belts prior to an event.
    There are ADR approved one piece race seats, which should be OK for "street legal".
    Gary
  2. #1102
    nsw
    The engineer I spoke to said that a hatch (or any 2 door, 4/5 seater for that matter) has to have hinged seats in the front so that rear occupants can get themselves out or be extracted easier. Having a 1 piece on sliders doesn't even qualify as the rear occupants cant reach the adjuster and it may not afford enough room anyway. He said you also cant de-rate the seats safety so if its an airbag equipped seat standard then you cant install one without. If it was just me I wouldn't care but the kids are in the back all the time - happy to risk my own neck but not theirs. So until I get it registered as a 2 seater I'm limited to an equivalent seat (none of which are lighter but may have benefit of harness holes in the shoulders) or doing seat swaps. A snookered situation but things can be improved I guess.
  3. #1103
    Apr 2015
    I have no doubt the engineer is correct, but the policeman looking in your window and seeing an ADR approval on the seat is unlikely to know what an engineer knows. Especially considering the small time factor involved in driving to and from events. As I mentioned for events I used to add (before) and remove (after) things like seats, harnesses, bonnet restraints, camber, brake pads, catch cans, battery etc. Of course it wore pretty thin after a handful of years and I graduated to a trailered "race car".
    Gary
  4. #1104
    Jun 2017
    Newcastle, NSW
    I tend to agree with Gary's point of view, but it's all a personal risk assessment I guess.
  5. #1105
    nsw
    oh yeah pre event I'll happily fit a 1 piece with ADR - I get why you mentioned that now. thanks
  6. #1106
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I found this thing to be great.
    CG-Lock Seatbelt Safety Devices
    Hooroo.
  7. #1107
    nsw
    yeah I use something similar - a clam type thing like that that you use with child restraints/seats to hold tension on the capsules. Free with each kid seat ha ha. They do lock your hips down and help keep you in place so that you're not fighting the G's but I'm not sure they'd do much extra in a crash.
  8. #1108
    nsw
    So a big night on the car last night..Lately id wanted to see how the stock farb would go with this suspension and after having trouble through the rough hillclimb track last weekend, decided id swap it out . I also wanted to see if there was any more caster available from the subframes and since they need to be dropped to get the bar in and out it was the right time .
    My god getting the old bar back out and the new one in is like doing a mechanical rubics cube . A major pain in the arse job. If it wasnt late at nightwith neighbours/kids in bed id have knocked out the ball joints and tie rods to get a bit more wriggle room. The way i found is to get the drivers side of the bar on the front side of the driveshaft and subframe, but leave the passenger side one loose inside of the subframe (subframes still dropped though). You can then get it out the passenger side guard upwards at a 45 degree angle.
    With the bar out of the way i replaced the rubber steering rack bush (passenger side only, the drivers side is solid any way) with a superpro mk5 Polo gti one (direct fit). Then i got the stock 19mm bar back in, arranged the eccentric bolt sleeves in tbe subframes so that the front bolts had the subframes as far forward as they would go and the rear eccentrics kicking the subframes out to the sides.
    Today i bolted up the farb with my body weight in the drivers seat, backed the camber off to 2.4 degrees neg for the street and reset the toe. Ill be heading to the aligners soon to get some caster numbers and to get some definitive readings of the rear beam/toe shims so that i know where im at before i put simonk,s track widening rear spscers onto the rear beam . So ill get caster numbers later but the wheels are ridiculously far forward in tbe guards now. Im going to refit the OE 16in rims for the street.. They are ET38 so if i can ill swap tbe offset tie rod ends side for side to get the steering arms a bit more lateral in case they run tne risk of touching a driveshaft or something reaching so far forward like they do.
    On the stock farb and the 450lb/in fronts i must say there is a definite ride quality improvement on tne street . Wont know till i track it if ive gone backwards but i have a feeling itll be better for the rsllysprints and rougher hillclimbs but it could be a different story on tbe circuit.. We'll see i guess. Pics to come.
  9. #1109
    nsw
    Andrew you're famous - check out the main page.
    http://hillclimbnsw.com/report-2018-...ley-hillclimb/
  10. #1110
    nsw
    Sam's build thread-img_6691-jpgsuperpro SPF3615K Polo 6R/Mk5
    Sam's build thread-img_6694-jpgright front
    Sam's build thread-img_6695-jpgleft front
    About as much caster as you can get without modifying the guards by shifting the hub forward. Car feels great and hopefully I can run with a tad less camber at the hillclimbs and have better power down traction.
    edit: and before you tease me, yes that front ride height is intentional.
