We run either the standard cast alloy sump with baffles OR we go dry sump. Modern engines have pretty good sumps and they are (in general) integrated into the overall block rigidity, especially for high performance engines. For example Honda has 2 sump designs one cast alloy and the other pressed steel, the engines with the cast alloy sumps have higher rpm limits than their equivalent pressed steel sump engines.
My suggestion would be to look for a baffle insert that you can fit to your OE sump. I know Forge make one Forge Motorsport I High quality performance Motorsports parts & tuning specialists
Gary
