Originally Posted by
sambb
well I can say after driving the car around with the new timing gear on it that it is really crisp, boosts faster with a much more responsive bottom end and has lost nothing discernible at the top. How much can belts stretch? The old belt/original pulley appeared a smidge behind the cam timing mark before I removed it - can a belt stretch far enough in its normal service life to have the cam off a touch. Well with the new belt and CatCam pulley on, the pulley timing mark (which I transferred across) was if anything the width of the mark advanced. This would be most likely due to keyway freeplay in the new pulley (which wasnt as precise as the OEM) and a fresh tight belt yeah? Either way the car definitely feels better down low, undeniably so, so in the short term I'm happy.
I can't say for VW's but Skyline cam belts stretch enough to make around 1 to 2 degrees of cam timing difference, which occurs very early in their life and then they don't stretch much after that. So we usually check and adjust the cam timing after 1,000 k's or so. Might be worth checking yours around then.
Advancing the inlet camshaft timing 1 or 2 degrees is not a bad thing, could account for the increased mid range response. But advancing the exhaust camshaft timing, whilst OK at low rpm, is not so good as the rpm rises. If I had to guess I'd say 2,000 to 4,000 rpm it might be a tiny bit better, but I suspect that over 5,000 rpm it will be tiny bit worse. Which for what you use it for is probably not a bad result.
Gary
