Originally Posted by
sambb
I only had 3mm total toe out front and 1mm total rear. 2.75 deg neg front and 1.50 dgree neg rear. With the rear damping of its 12 click range I was 4 clicks out from full hard before it started to turn. That's what made me think I was compensating for excessive front stiffness and made me think of the front bar, but yeah more rear toe needs to be tried first I guess.
Re the tryes, yeah that would be great. Any way I look at it I think 215 is the way to go for the track now. thx
As I think you already know I'd run ~4 mm toe out on the front and ~6 mm toe out on the rear. As long as you can dial out the understeer with rear adjustments (swaybar, toe, damper) I wouldn't be changing the front. Only when the rear changes reach their limit would I look at softening the front.
The rear camber effect is interesting, more neg (less contact patch) means it turns in better. But the grip improves (more contact patch) as the body rolls, so as long as you have power on it should never mid corner oversteer. It also works the same for low G/speed corners (less roll) compared to high G/speed (more roll) corners. Getting corner speed out a FWD car is much more about the rear end than the front, which some people just don't get.
No doubt some corners need the overall speed reduction from braking, but some only need a lift off to get the nose pointing at the apex. The trick is learning which is which, then being confident enough to add early power to pull it straight.
There wasn't many running the 215/50/15 but a couple of new guys are this year, so I'll keep them in sight.
Gary
