Looks good Sam, nice job, but I'm not sure that it was worth the effort and time. At the other end of that pipe is 100,000 rpm "vacuum cleaner" sucking away and providing airflow to the engine (making boost). If you have a boost target of say 1.5 bar and with the "super duper inlet mods" the turbo can achieve that at, say, 100,000 rpm (shaft). Compared to no super duper inlet mods it might need 101,000 rpm to make 1.5 bar. The engine doesn't care as it's still getting the same airflow and the increased shaft rpm (to overcome the slightly higher resistance) will be so minor as to be inconsequential.
This is why we find some manufacturers bother with "super duper inlets" and some don't. Quite often I suspect that they use whatever is in their parts bin, if they have a suitable one they use it, if not they don't bother engineering one.
On a normally aspirated engine the inlet is very important and we go to great lengths to maximise the airflow, we chase every single horsepower. But a forced induction engine, no so much, we can easily increase the airflow using the turbo and pick up 10 bhp.
Gary
