Page 69 of 190 FirstFirst ... 1959676869707179119169 ... LastLast
Results 681 to 690 of 1896
Thread: Sam's build thread
  1. #681
    Apr 2015
    In Newcastle the Mayfield East and Merewether Uniteds have E85.
    In Tamworth the United near the Golden Guitar has E85. That was pretty marginal non stop in the Evo, so we used to carry 10 litres just in case. Filling up at the Uniteds on Rookwood Road now we wouldn't have to.
    Gary
  2. #682
    nsw
    Hmmm really wondering about E85 now. If not too much hardware needs to be changed then I may do it. I have 3 and 4 bar fuel pressure regs, both the 2.5 and 3in MAF housings so can go up to the bigger housing if they think the MAF will top out. A bigger fuel pump in there already (but not sure if its E85 safe). I'll have to find out if audi S3/TT 225 380cc injectors would have enough headroom (stock is 315cc) for a modded K03s or if bosch 550cc's would be the go. I guess we could do the 380cc ones on the 4 bar regulator for E85 and then I could always go back to the 3 bar reg and retune for petrol if E85 proved to be a pain.
  3. #683
    Apr 2015
    Some very basic (ie; rule of thumb) maths for injector size versus bhp (that's at the engine, as on an engine dyno);
    At 12 to 1 air fuel ratio for petrol 1 x 300 cc injector (at its rated psi) will provide enough fuel for around 50 bhp, so 200 bhp in a 4 cylinder.
    315 cc = 210 bhp
    380 cc = 250 bhp
    550 cc = 360 bhp
    Keeping in mind that that's petrol, 12 to 1 AFR and standard (rated) fuel pressure. Obviously the flow increases as we add more fuel pressure and we need around 25% to 30% more E85 for the same bhp output. That's not allowing for any increased bhp as a result of being able to tune it higher as a result of using E85 (ie; more ignition advance etc).
    If they are rated at say 3 bar fuel pressure and we increase that to 4 bar and allow say 30% more fuel for an E85 friendly air fuel ratio around 9 to 1, the result is;
    315 cc = 215 bhp
    380 cc = 260 bhp
    550 cc = 370 bhp
    That still allows enough flow for acceleration enrichment and cold start enrichment.
    Since fuel injectors cost pretty much the same regardless of how much they flow we use the biggest ones we can (eg; 2000 cc injectors for a 280 bhp N/A 2 litre). That way we can move the injector timing around within the combustion cycle, which is important when we use up to 10,000 rpm.
    Remember, just rule of thumb calcs and that every engine is different.
    Gary
  4. #684
    Apr 2015
    Quote Originally Posted by sambb View Post
    Separate thoughts on this one;
    In theory (that rule of thumb again) you could drive to an event on pump 98 on the 3 bar FPR. Drain the tank and fill it with E85. Then swap the FPR over to the 4 bar one and do the event. Then drain the tank, fill it up with pump 98, swap to the 3 bar FPR and drive home.
    Not suggesting that you should do that, but you that could. Or in an emergency when you couldn't find any E85, it might save your ass, maybe close enough AFR's to get you home.
    Gary
  5. #685
    Oct 2017
    Wodonga, Vic
    how about swapping ECUs? e85 on one and 98 on the other
    though loading a tune only takes a couple of minutes, as long as you carry a laptop everywhere
  6. #686
    nsw
    actually that's a very good idea the swapping of ECU's. Have an E85 one ready to go, with a defeated immobiliser on it, and a separate one for the street/petrol. An ecu swap now that the airbox and battery are out of the way takes about 2 minutes. For the time being most of it has been settled on. Initially at least i'm going to do a 98 petrol tune. I'm buying 550cc bosch ev14's (that can do both although they may need a 4 bar fpr on a hybrid if I go that way but will be fine on the current turbo). Judging by Gary's info (thanks for that) they should be fine for what I have on the 3 bar and maybe even for a hybrid if its not too extreme. S3/TT225 380cc would have worked but would give me no headroom for even e85 on the existing turbo so I discounted them. I'll use stock 3 bar fpr and the 7psi wastegate spring. Its still up in the air whether a 3in MAF housing is needed. Once I've got the 4 bar fpr which is in there now tuned enough to do some WOT runs, i'll be able to see what the max MAF g/s flow is. I think anything that is approaching 200g/s is meant to be topping it out so if that happens then the bigger MAF may be needed for the proper tune but that's up to the tuner. First things first though I need to find the correct length 550's for the right price and surprisingly domestic looks to be the go. But yeah I'll be keeping an eye out for a spare ECU from now on - regret selling my old one now.
  7. #687
    Oct 2017
    Wodonga, Vic
    maybe talk to Louis - I was going to hit him up now that he's replaced it...
  8. #688
    nsw
    Ordered my Bosh EV14 550cc injectors today - 53mm o-ring to o-ring, with the connector adapters for our loom. A tad over 300 bucks delivered from VPW in Melbourne was pretty good too.
  9. #689
    nsw
    MY MATES AR-1 TEST: So my mate was out at the Eastern Ck south circuit today with the Renault car club testing a new set of Nankang AR-1's. He has two sets of Rega's and so had a very fresh set of same size 195/50/15 Yoko A050 mediums on hand to compare them to. The Yokos had been oven baked by Gordon Leven and had done only two 7-9 lap sessions at Wakefield when we were there in January (22-25 degree day though). The Nankangs were bought new 2 weeks ago (late 2017 build) and he'd done a street scrub on them a day and a half before the event. He said based on finger nail duro test they were softer than his Yoko mediums. Today was about 26 degrees on the coast so could have been nudging 30 degrees at the track I'm guessing.
    His car is a W172 renault Clio 2 litre atmo. Standard 4 into 1, W182 inlet manifold, W182 cams with some cam timing changes and a plug and play aftermarket ECU. It has nearly 160hp at the wheels but wouldnt have our low rpm torque. Car is road registered engineered 2 seater with 4 point cage. 6kg front and rear springs. Stock front bar, big rear bar. Toe out everywhere, 3 degree front neg, 2 degree rear neg and roll centre/steer correction kits. weighs 1050kg with 1/4 tank, no driver. Rear beam, mac strut setup just like ours and close in weight.
    He said his first session was taken easy so that he could sight the track and get the tyres up to temp and see how they were going with pressures etc. He said he then did the next three sessions and really struggled with the car. He said he was fighting the car struggling to get it turned in, despite the quaife he was getting straight linepower on wheelspin out of the slower corners and found that the car was sliding laterally a lot. He said he actually wasnt enjoying himself and was wondering whether it was because he was on a new track and was getting the lines wrong, or if it was the stiffer 6kg/mm springs that we'd put in the back. He said he could feel them go off a bit to in the later sessions. Not sure if that was pressure related - forgot to ask. He said he tried 32psi hot, 34 psi hot, 30psi hot and came in on one session and set them to 29 psi front 31psi rear to see if that would help get the thing turned in. Throughout all this he said his times were all within 5/10th of 1:09.50's.
    So in the last session he thought he'd go out on the Yokos. They were stone cold so he set the fronts at 24 psi cold and rears at 27psi and he said immediately it was like they were an old friend. The car was balanced sharp and doing what he told it. He said his laps for that last session considering also that he was coming up from stone cold low pressures were same deal all within 5/10ths of one another but 2 SECONDS quicker - all around 1:07.5's.
    Glad he was the guinea pig because I was going to do it myself, so its a bummer that a nice cheap semi that had had good reports on small cars doesnt seem to hold a candle to the Yokos', and a double bummer that it seems to be that once again you get what you pay for and pay for Yokos you surely do! Whether any of this holds true for bigger cars I dont know but as a good basis for comparison against our car. He said they are still better than his 'street semi' Yoko AD08R's would have been, but markedly off the Yoko's. They'll be on gumtree if you want em cheap!
  10. #690
    nsw
    Question for you Gary. Hankook TD r spec only have 195/55/15's. I'm after 215/50/15 to put on my 7in rims on the fronts or 205/50/15 if you think that's a silly thing to try. The only two I can see that do it are Yoko A050's in medium and Dunlop Direzza D03G. In previous posts you mentioned that you rated these Dunlops yeah? They are R2 compound. Is that their medium? Do you know how that compares compound wise to a Yoko medium, because it would probably have to double duty as a hillclimb and rallysprint tyre too. Don't have the dollars anymore for a soft and a medium set - thinking Ill end up on mediums for everything.
