Page 57 of 190 FirstFirst ... 747555657585967107157 ... LastLast
Results 561 to 570 of 1896
Thread: Sam's build thread
  1. #561
    nsw
    Must admit I don't know the pressure drop of the SEAT sport fmic. All I know is that guy Harding did a test years back on the stock side mount versus the forge fmic and the forge was very restrictive. The seat sport I have is meant to be a less restrictive design than the forge but ultimately is the same double pass type so I can only assume it may be worse than the stock smic. It's easily a meter and a half more pipework to fill with it. I guess also it's not apples versus her apples because the other setup used water injection which helped it run more timing. I'm thinking there was stuff all pressure drop so the turbo was closer to its comp efficiency island , flow was high, yet temps were low due to the water and knock prevention was way up. After a hard run the plenum used to be actually chilly to touch sometimes.
    Interesting what you said re the 10psi drop from 20psi on a small lift. I'll keep an eye on it. I do have a stiffer spring I can throw in if need be. Tell you what a k03s with the unmuffled comp housing after I straight piped it is a noisy thing. DV action plus Comp surge is pretty dam loud and unavoidable being such s small turbo.
    Sick today do spent the afternoon picking rubber pickup gum balls out of the tread cuts in my softs. Lots of them were blocked completely. I'm pretty anal like that but if I'm going to be confident to go hard in the wet then I need to know I've crossed that off. Fingers hurt now though!!
  2. #562
    Apr 2015
    Quote Originally Posted by sambb View Post
    The 20 versus 10 psi is a "rule of thumb" thing, a place to start. It has to be high enough pressure so that when you crack the throttle open it doesn't go to vacuum, because then you get the nothing ......... nothing ............ woooo hang on tight. Which just makes the driving on the limit rather tricky. But it has to be low enough pressure so the airflow doesn't reverse direction, which is bad for the lag but also not good for the turbo. Unfortunately that means trial and error.
    I guess VW installed the muffler in the comp housing for a reason.
    Whenever I am using a "new" intercooler I always check the airflow resistance and the cooling efficiency, some of them are terrible at one and good at the other. It's hard to actually find one that is good for both.
    Without water injection you really are comparing apples and oranges. Inlet manifolds, even in a hot engine bay, can get very cold even without water injection. In winter on top of the mountain at Bathurst, on damp mornings, I've had Webers (yes, I am that old) freeze the butterflies. That for sure get's one's interest. Even with a Holley on top of a V8 I have had ice in the venturies at Philip Island.
    Gary
  3. #563
    nsw
    Yep muffler definitely muffled when it was there. But it would have been a flow mangler so its gone. My wife backed it up the driveway the other day and lifted off and after the ch ch ch ch she just looked at me and said 'what have you done to it now'. I just feined ignorance but she wasn't buying it.
    Did a test of the DV and did a little kid corner lift. Boost went from 1.4bar down to 0.5 bar on the gauge. When I got home I pulled it apart and unfortunately I have the medium spring fitted and my spare is the soft. The hard cracks at between -19 to -24in/hg so will probably be more appropriate. I thought about washering it to give it a bit if preload but didn't have anything to fit. So what I did was change the DV orientation so that the boosted air is pushing into the side of the piston in the hope that it'll need a tad more of a pull from the diaphragm to get it open since boost won't be additive with the diaphragm signal in this orientation.
    I'll have to see if there are any throttle body inlet pipes that have DV ports on them because I really do see what you are saying re dropping the boost at the throttle plate rather than through the entire length of the induction system. Keen to try that.
  4. #564
    Apr 2015
    I've learnt to own up first, they have a knack of catching on especially after 30 years of experience.
    Worth a try, when I was first playing around with turbo cars for myself and my son we tried all sorts of things, dispelled a few myths and found quite a lot of "givens" were not only illogical but were just flat out wrong. Air flow (like aerodynamics) is still more trial and error for me than mathematical calculations. For adjusting blow off valves I originally had a number of discs that I cut from 1.5 mm thick aluminium sheet, shims, that I would stack up until I achieved the desired result. Once I achieved that I'd make up one shim and replace the stack. On the Skyline I have 2 HKS blow of valves, it needs a lot of venting, and I still haven't got them set up exactly as I want.
    It's simple aerodynamics, rule #1 keep the airflow going in the same direction.
    I used to use off the shelf adaptors, like these, from GCG I think. Just choose one that fits the rubber hose and cut out a section.
    Gary
  5. #565
    nsw
    re the diverter valve yep that's exactly what I was thinking I'd have to do. I'll see what GCG have and if there's nothing to suit ill get some straight pipe welded up.
    Gary I'm a bit unsure about what pressure to set the 195/55/15 A050 softs for Bathurst. I've never run them on the new suspension/angles. Lateral G's will go up so despite the extra camber I'm thinking I should start them at 30psi to try to keep the tall profile a bit more rigid than running them down at 28psi on the old setup. thoughts?
    If its dry on day 2 for mountain straight (depending on how day 1 goes) I may bump up the front bar to hard and follow that at the rear for the more drawn out corners. I never got to try that at Wakefield but surely its worth a shot to stiffen the whole car for the Reid - Macphillamy Pk sectin.
  6. #566
    nsw
    Andrew Andrew bring those AR-1's. They just updated the weather and they are saying 30/31 degrees both days mostly sunny.. No rain forecast yay!!!
  7. #567
    Apr 2015
    The recommended target how pressure for A050's is ~31 psi, that's what I've the best success with as well. That's pretty easy for circuit racing, I have a data base for most circuits and most ambient temperatures which means I have a cold starting pressure that should end up at 31 psi after a couple of laps and not continue to build. Plus we have driver adj swaybars so we can temper the manic FWD cold tyre oversteer for the first race lap or so. In hillclimbs you don't have that luxury, so it's a bit of trial and error plus constant adjustment during the day. My suggestion would be to start off for the first run at say 30 psi in the rear and say 28 psi in the front. Then measure it straight away at the end of the run. You should be able to get 2 or 3 psi climb with front burn out etc, maybe 1 or 2 psi with the rear G force loading. If they are over 31 psi then I'd let them down, if they are under pump them up. For the next run, they should be still a bit warm, especially if it's 30 degrees, so you may not have to touch them. Just keep checking before and after each run and adjust accordingly.
    I agree, I'd run a bit more anti roll and maybe a bit more damping for the Mt Straight runs. I suspect you may end up chasing tyre pressure all day there.
    Have fun
    Gary
  8. #568
    nsw
    argh got your message too late Gary - think I was close anyway. On the Esses I was starting front 29 back 30 and was ending up at 30/1/2psi all round (inc a tyre warm) and in mountain straight I was starting at 28 front 29 rear and was finishing just under 31psi all round.
    Was an awesome weekend. Despite slowwwww times from the whole field (like 3 seconds slower for an esses run????) where everyone except the club was certain there was a timing error, I can guarantee that not a single PB or record fell. So if you put times out of the picture and just look at the standings then I know the car was amazing compared to where it had been. Against the exact same top 10 opposition as last year in road reg >2.5L where I finished 6th at the Esses and 13th on Mountain straight, I improved to 4th at the Esses and 5th!!!! on Mountain Straight.
    Mountain Straight was where I could really feel the car doing its thing. It was planted on the softs without any scary sideways action going into Griifins which was my big fear and gave me a hell of a lot more confidence from Reid to Mcphillamy. Against a field of atmo/cammed/blown V8's I was pretty consistently 4th fastest on the first split which means the turbo swap was worth it because that takes in the straight, Griffins and the run up to the cutting, but also says I was getting through Griffins faster than them for sure. One of the marshals had a radar gun the first year I was there so wish I knew what the griffins apex speeds were but I had to have been going quicker than them there given the horsepower defecit. I finally cracked how to line up the crest before you drop down the other side towards the grate. I'm not saying I was where I needed to be each time or that I wasn't chickening out on the throttle half the time but I knew where I needed to be and got it rightish on the last run. I still could go quicker of course but that's just hillclimbing - you get 4 looks at it all day on cold tyres so your never going to nail it.
    So Gary super happy with the suspension. I definitely see that 3 degrees front neg whilst enough for the esses could have gone out to 3.5 for mountain straight. Now that the cars front:rear roll distribution is working the rears more equitably it was interesting to actually see consistent wear on all 4 tyres rather than seeing chundered fronts and no pressure rise in the rears. I was running 3mm toe out on the front and to be honest it didn't worry me at all and the zero toe at the back gave no surprises so I'm pretty happy to go to 2mm rear toe and take the rear camber out to 2 degrees neg now for sure. I didn't go up on the bars for mountain straight or even the dampers. The car felt very consistent and all the time was going to be in me just growing a pair really so I left it alone and just concentrated on not repeating mistakes and on resisting the urge to back out of it.
    Got lots of vids but it'll me a bit to get them up.
  9. #569
    nsw
    Andrew did you get the email. They just sent one out admitting that the timing was out. What ****s me is they had people telling them with logs/video time stamps etc on day 1 that it was out and they just waved everyone away and let day 2 happen the same. They even told us they'd tested it on day 1 which they clearly hadn't because now they say they tested it and it was out. Apparently placings and relative times between everyone are correct and were consistent across the days which suggests a timing offset was thrown onto everyones times on split 1 like we all suspected. I've responded and asked if they can at least tell us what the suspected offset is so we can get an idea of what our real times would have looked like. Pete went feral at them and wants his money back.
  10. #570
    Oct 2017
    Wodonga, Vic
    sounds fantastic - I've been digging through lots of your threads - you're a legend for publishing all of this stuff!
    DIY adjustable camber ball joints mod
    My first sprint (DECA Wodonga) with the Polo is this weekend, it'll be stock with miserably bad "blacklion" tyres so the only way is up. A mate and I messed around a rear bar stiffener on Saturday between jobs on another car, but it was too hot and I was exhausted, maybe I'll do something with it this week. Otherwise the only thing I've done is disable the throttle cut on left-foot braking... at least I can only make improvements
    question for you - you run wheel spacers (I think), but have you thought about some spacers behind the stub axles instead?
