The only thing left to do is get some proper 50mm nickel coated clamps that are rubber lined and can be bolted down in place of the cable ties I have on the control arms. All up though standing back and looking at it, it should actually work. At Bunnings, look in the section where they have the irrigation/drainage fittings rather than the plumbing stuff - there were a few things in there that were contoured better and in the sizes needed. Another option I saw for a flush mount fitting was a plastic shower drain fitting. You could hole saw a front aparon facia, push the fitting through from the outside and then tighten the nut on the back. It had a nice curved entry and about a 60mm outlet - just wasn't going to work with my facia though.
