![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
sambb
Re hardware issues that arise due to ducting, I'm thinking that a blanking plate over the duct intake is going to be necessary, not just to prevent cooling when I don't need it but to stop every bit of wet road grit (especially salt if you are in the UK or something) and crud getting accurately guided straight onto the rotor in normal driving.
The problem for standard rotors for our car seems to be choice. QFM A1RM's need to be shod onto used backing plates, EBC green stuff has been discontinued and they only do red stuff, which pretty much just left DS2500. There's a lot of reasons why I run 15's but the fact that I didn't want to sling more brake hardware weight at it was one of them. That's fine for hillclimbs and sprints but hopefully it won't fade drastically at wakefield 20 min sessions. Whats the g limit for say A050's in 205/50/15 in a 1100kg FWD with my suspension?
Yep, that's the problem with brake ducting, especially melted tyre rubber in the rotors, very hard to remove and smelly. You could run air filter element or foam from Clark Rubber in the vent inlets. Or maybe race tape them up when not at the track.
You'll be lucky to see 1g, I'd expect something around 0.75g at the fishhook.
At Wakefield 20 minutes is going to be hard on brakes in summer in a road car with a reasonable power to weight ratio. It's also going to be hard to keep the tyre pressure (and temperature) under control. A050's are very tyre pressure sensitive so my approach would be to start off at around 24 psi cold (staggered as per previous post), then stop after 5 or 6 laps and adjust to a max of 31 psi all round. Note how much you have to bleed off, if it's more than a couple of psi then I'd stop after another 5 or 6 laps and check them again. I wouldn't do a slow in lap, come it hot, but then do a slow out lap to stabilise the brake temps. It would be good if you had someone to help, do 2 tyres each, that will minimise the heat soak while stationary. You should only need do that in the first session and maybe again after lunch, as the ambient temperature can change drastically during the day.
During the lunch break I'd have a good look at the tyres and see what they are telling you, especially check the left front for blisters.
Tip, write everything down in the book with the pencil that you have with it in the glovebox, after every session, before you forget.
Gary
