Page 40 of 190 FirstFirst ... 3038394041425090140 ... LastLast
Results 391 to 400 of 1896
Thread: Sam's build thread
  1. #391
    Jan 2009
    Great to see the progress. I've not had issues with the bolts coming loose. Just use the recommended bolts and gasket.
    I'm curently of the position that they come loose when they get over tightened. They require very little torque, like 28 pound foot or something if I recall. They're a stretch bolt so just need to stretch with elastic deformation.
    Yeah if you're not redoing the tune I'd run the 7psi spring. Though if you're retuning I'd be cranking up that spring rate to 3-5psi below what you're planning to boost it at (e.g 15psi spring). I'd had done this had I known of this stuff at the time.
    Daily: 2010 VW Jetta Highline
  2. #392
    nsw
    Yeah the bolts are only like 40Nm which is nothing really. Dunno I just can't really trust such a pissy torque spec on such a big bolt. It could be that the gasket is not designed to be squished completely flat and retain a bit of spring - not sure. Still torn on what spring to use. When I was running stage 2 exhaust and the modded turbo/mani but with stage 1 tune (with some hardware fettling to make it work) I was actually running a 12psi spring! With water injection I had zero timing pull set up like that and it went pretty hard. I honestly think the new 10psi spring I have will be spot on - a perfect split the difference considering how much more pressure is going to be sitting behind the gate. I will initially use the 7psi spring till it all finds its feet though. The K03s spools it tits off anyway and from experience I found that the spring strength had very little effect on the boost ramp because of this. Where it could be felt was how the spring would govern the way that the boost falls away after the boost peak. On the modded turbo even if the N75 was telling the actuator to close up on the spring I don't think it'd have had any effect with a 6psi spring. anyway time will tell. If I can work out how to post VCDS logs i'll be able show if it'll cop the same amount of timing with each spring and maybe graph boost curves with each too.
  3. #393
    nsw
    Sam's build thread-img_5367-jpgSam's build thread-img_5369-jpgSam's build thread-img_5371-jpgSam's build thread-img_5373-jpgSam's build thread-img_5374-jpg
    I changed my front pads for some fresh Ferodo DS2500's for the upcoming track day. At the same time I wanted to remove the brake disc backing plates to make way for some cooling ducts that i'll run. So if you go wheel off, caliper off, disc off in that order you'll be left looking at what is in pic one. Its then just three 8mm spanner bolts to get the backing plate to slide clear.
    The Ferodo's and a lot of other trackable pads do not come with the pad wear indicator lead on them. The pad wear indicator exists only on the passengers side inner pad. This stock or stock replacement pad (inc Bendix, remsa) will have a plugged cable from it. Basically it is a loop a closed circuit that opens when the pad wears thru it. So to fit other pads without this lead you just have to short the cable on the car side that this pad lead normally plugs into. You have two options you can cut the lead off a stockpad, solder/heatshrink the two wires together and then plug this in to where it normally goes. The advantage of this is you can do it easily on a bench and then refitting is just a plug in. To me that was bulky though, you still have bulky plugs at the strut base and a tail to tie out of the way. So I just cut off the plug in the car side, shorted those, folded them up against the cable and heatshrunk the stub - no plugs or clutter now. I'd have soldered but I was out of gas so I just crimped it instead which is bodge to me but I had to get it done. Now if I fit remsas again I just have to snip the lead off the passenger inner pad as it'll have nowhere to go. Electrically the car will think I'm running a juicy fat pad no matter what is in there, but really who doesn't check their pads visually anyway.
    Last pic is everything refit with new pads sans the disc backing plate and ready for ducting to go in soon.
  4. #394
    Jun 2017
    Newcastle, NSW
    Cool. I'm planning to hack up my backing plates and use them for the ducting - remove all the plate adjacent to the disk surface and then cut a hole and weld some tube near the centre to attach the ducting to. I figure by still having the backing plate behind the centre of the disk/hub it will help to force the ducted air through the disk, and it's a convenient ready made plate for attaching the ducting.
    The below pic is from Carroll Smiths "Prepare to win":
    Sam's build thread-wp_20171231_12_34_43_pro-jpg
    Edit: Not sure if I'm going to make it to Wakefield in a couple of weeks or not. Still waiting on my new brake parts to ship from the US...
  5. #395
    nsw
    I spoke to Tilleys in Sydney about brake ducting setups and they said that hands down the best method they've used is for the ducting to force air into the disc centre so that air is forced outward through the disc vents and cools the disc evenly from the inside out. But they said that obviously with front wheel drive and the CV in the way this is just not practical and needs directional vents in the discs to work properly. They said second best is to do what we are thinking of which is to retain a backing plate (modified standard or a dedicated aftermarket) and force the air into the side of the backing plate so that the inside surface of the disc gets an all over blowey and some may find its way through the inner part of the disc and out through the fins which is what your pic shows. On your fronts you'd have a radius/toe arm wouldn't you that you could run an angled duct along?
    Sam's build thread-th-jpg Method 1
    Sam's build thread-th3npzcq4c-jpgSam's build thread-viken_brake_ducts-jpgSam's build thread-3911plate_installedii_600-jpgmethod 2
    Sam's build thread-th0m2nodzp-jpg method 3: what I'll be running until I can get method 2 happening
    Sam's build thread-gts_brake_duct_2_79e99a5e451eb7569adeaf70f9bcddd04c02f795-jpg or maybe this. Still run ducts but have them feed a channel/plate that guides bulk air to the whole inside of the disc.
  6. #396
    nsw
  7. #397
    Jun 2017
    Newcastle, NSW
    Ah right, I didn't consider the extra stuff in the way for front wheel drive, and strut is probably a bit harder as well. I should be able to get a good approximation of method 1 which is the same as the diagram I posted. The Vette has twin A arm front suspension, and from the brief look I've had so far (my ducting hasn't arrived yet), I'll probably run the ducting out along the upper control arm.
    That Golf is pretty awesome too!
  8. #398
    nsw
    So whats the plan Andrew - not going to do Wakefield again till you get the ducting sorted?
  9. #399
    Apr 2015
    Due to their high maintenance and frequent hardware issues I pretty much avoid brake ducting wherever possible, of course for long distance races (3 hours, 6 hours, 12 hours etc) it's pretty much a necessity. But for most of the stuff we do the races are less than 30 minutes. So I spec the braking components such that they are more than capable of achieving top performance over the race distance. Overall braking performance is generally limited by the tyres, for example it's not of much use having brakes capable of generating -2.5g when the tyres won't handle much over -1.5g. It's just adding weight for no benefit, unsprung weight at that.
    Personally I'm not a fan of DS2500's (or DS3000's for that matter), I have found their performance to be inconsistent, variable dynamic friction coefficient within the same compound, excessively ambient temperature sensitive with additional variations in retardation as the pads wear, as well as the occasional lack of backer rigidity. For a long time I have mostly uses Hawk pads and as a result I have used all of their compounds. That experience means I can diagnose and find a solution to a pad related problem quickly, order the relevant part numbers from the US and have them here in 4 or 5 days. Although I do have one driver who prefers the feel from Willwood's Poly Matrix pads, which are also slightly kinder on the rotors.
    Being a suspension guy, I also work really hard on maximising the cornering speed hence the need for extreme levels of braking performance aren't as necessary ie; the delta between the maximum straight line speed and the cornering speed is reduced as much as possible.
    Happy new year to All
    Gary
  10. #400
    nsw
    Re hardware issues that arise due to ducting, I'm thinking that a blanking plate over the duct intake is going to be necessary, not just to prevent cooling when I don't need it but to stop every bit of wet road grit (especially salt if you are in the UK or something) and crud getting accurately guided straight onto the rotor in normal driving.
    The problem for standard rotors for our car seems to be choice. QFM A1RM's need to be shod onto used backing plates, EBC green stuff has been discontinued and they only do red stuff, which pretty much just left DS2500. There's a lot of reasons why I run 15's but the fact that I didn't want to sling more brake hardware weight at it was one of them. That's fine for hillclimbs and sprints but hopefully it won't fade drastically at wakefield 20 min sessions. Whats the g limit for say A050's in 205/50/15 in a 1100kg FWD with my suspension?
