Due to their high maintenance and frequent hardware issues I pretty much avoid brake ducting wherever possible, of course for long distance races (3 hours, 6 hours, 12 hours etc) it's pretty much a necessity. But for most of the stuff we do the races are less than 30 minutes. So I spec the braking components such that they are more than capable of achieving top performance over the race distance. Overall braking performance is generally limited by the tyres, for example it's not of much use having brakes capable of generating -2.5g when the tyres won't handle much over -1.5g. It's just adding weight for no benefit, unsprung weight at that.
Personally I'm not a fan of DS2500's (or DS3000's for that matter), I have found their performance to be inconsistent, variable dynamic friction coefficient within the same compound, excessively ambient temperature sensitive with additional variations in retardation as the pads wear, as well as the occasional lack of backer rigidity. For a long time I have mostly uses Hawk pads and as a result I have used all of their compounds. That experience means I can diagnose and find a solution to a pad related problem quickly, order the relevant part numbers from the US and have them here in 4 or 5 days. Although I do have one driver who prefers the feel from Willwood's Poly Matrix pads, which are also slightly kinder on the rotors.
Being a suspension guy, I also work really hard on maximising the cornering speed hence the need for extreme levels of braking performance aren't as necessary ie; the delta between the maximum straight line speed and the cornering speed is reduced as much as possible.
Happy new year to All
Gary
