Originally Posted by
sambb
Gary got another one for you: the 8kg/mm rear recommendation, does that still hold true considering I do primarily hillclimbs. While it might be right for circuit stuff I'm just wondering whether that'll be too aggressive for hillclimbs with dirty stone cold tyres. Just final checking before I order them.
No real black and white answer I'm afraid. It depends on what tyres you are running, the temperature on the day, the track surface, the track layout etc. When I was running a FWD car in hillclimbs I ran very soft (compound) tyres and didn't warm the fronts up too much, no big tyre smokin burn outs. As I didn't want huge tyre temperature differentials front to rear. I also used to take the rear wheels off and stick them in the sun between runs.
It's circular reference, #1 we don't want too much weight transfer off the front for the take off, so a high spring rate is a necessity (because you don't have separate bump and rebound adj in the shocks). But #2 we don't want too high a spring rate such that it rotates at the first corner. My preference would be the highest spring rate it can handle to optimise #1 and then use the swaybar to minimise #2. No amount of swaybar is going to help with #1.
I'm afraid the only real answer is to try it, sorry.
Gary
