Originally Posted by
sambb
I'm glad you said that because its worried me from the start that the front will be too stiff even at 8kg/mm. But my mates W172 clio is on 400lb/in fronts and it felt great which makes me think 450lb/in on the front wont be far off - just not sure.
Personally I always lean towards a softer spring rate, a slightly softer than perfect spring rate is tolerable and you can tune around it. But higher than perfect is always going to limit traction as it's much harder to tune around. On the basis of "more" swaybar and "less" spring, 400 lbs/inch is ~7.1 kgs/mm which is about where I'd recommend.
Based on my experience, Mark is as usual on the money, it's easy to overlook that a swaybar links the 2 wheels, so we can't look at one wheel in isolation, we have to consider both wheels. If we run a softer swaybar that means 2 things, the outside front spring will compress more so the inside front spring has to extend more to keep the wheel on the ground. If we run a stiffer swaybar that also means 2 things, the outside front spring will compress less so the inside front spring has to extend less to keep the wheel on the ground. Something to think about, a 200 lbs per inch spring takes 200 lbs to compress 1 inch and then takes another 200 lbs to compress another 1 inch. So the spring is pushing back at 400 lbs, another inch and it's pushing back at 600 lbs. Your car has approximately 800 lbs on each front spring, so whether it's a 400 lbs/inch spring at 2" compression or a 200 lbs/inch spring at 4" compression they are both pushing back at 800 lbs (to hold the car up).
In a straight line a swaybar does nothing, doesn't add to the spring rate. A swaybar only works when there is roll, whereas a stiffer spring is always a stiffer spring. A softer spring allows the tyre to more closely follow the road surface whereas a stiffer spring can cause the tyre to skip over the ripples and bumps, hence losing traction.
Gary
