Hi mate. yeah it did move the roll centre. The audi TT ball joint sat nearly 10mm lower than the vw polo one. That gives you two avenues - you can either keep the same ride height you had and know that you raised the roll centre, OR you can then lower a further 10mm and know that the control arm angles you had before are maintained even though the car is lower. ie my control arm pivots used to be level with standard springs. After the mod I fitted weitec uprated springs that were say half an inch lower than standard and the control arms are at the same angle they'd been with the stock height springs. So the car and its centre of gravity is lower, the OEM roll centre is maintained but you haven't sent the roll centre below ground level in the process. Before I did this mod I'd fitted H&R springs. The lower control arms were markedly up on the ball joint side compared to the subframe pivot and in my opinion it was woeful. Handled great at 8/10th but when you really started to lean on it the front end would just give up and it just felt edgy and unpredictable. Post BJ mod with same spring rate but slightly taller springs than the H&R's and its been brilliant, really consistent and predictable. I literally went from nowhere to getting good results on the track once I got all that sorted. However the up to 2/1/4 neg camber degrees you get if you do the mod by elongating the existing slots even more like I did would have played into that. I don't know what the max neg camber would have been if the standard audi TT ball joints' elongations were used but I'd imaginge it'd be up around 2 degrees. And honestly I have driven the ring out of on lots of tracks on soft semis and the adjusters have never slipped, not even a whisker so its strong as.
Yeah I found WI to be pretty dam good. My system was pretty agricultural. Just a boost triggered single flow rate through aquamists smallest nozzle pre throttle body. Thing is though I was injecting only 15cm before the temp sensor and I was getting temp drops of up to 15 degrees over that tiny distance on back to back runs and there would have been further cooling all the way through to the chambers. I could do a water injected run and have virtually no timing pull and then switch it off and have 7 degrees pull everywhere so that stuff works. I needed it because at the time I was on a stock smic and was leaving power on the table on hot days. I only used it at events where your really up it cos its single flow rate wasn't tailored for mid throttle etc. The pump mount which was in the tyre well got pulverised when I was rear ended so that was the end of that. I'm really keen to get the pre compressor WI happening. I basically have all the bits - I'm just waiting on a mate to sort out the HC20 full river battery and once I get that all wired in and the intake moved out of the way I can start mounting stuff.
