Originally Posted by
sambb
Alright you've convinced me Gary. 215 /50/15 makes perfect sense. The 225/45/15 (they have 225/50/15 too) V70A's are 2-3 year old new shelf stock from the kumho Sydney dealer. I'll have to weigh up the age and whether running so wide on the 7in rims will kill steering feel. If I am to run 225 on 7in rims, if you ignore rolling diameter, the 45 would be the better sidewall to run for that rim yeah?
As we talked about before, in regards to tyre profile (sidewall height) lower profile is better if the suspension geometry is set up for it. But a higher profile (tyre) is better if the geometry is not ideal as the increased sidewall flex can help retain the contact patch. The most important issue is bump steer closely followed by dynamic camber, if they are optimised then the lower profile should be better.
I did a bit of checking around on the Kumho V70A and the only consistent criticism (albeit from a small sample size) I heard was their lack of steering feel/feedback. Which the lower profile should help with. But in general not many people are using them, which concerns me. Personally I'd prefer to go with a known product, but it's your budget.
Gary
