Had a mildly bright light bulb moment today re the gearbox. I'd been running Motul 300 75W 90. I remember when I got the box built that the builder had said that was a little thick when hot for his liking for the synchros, but I went with it anyway as its what Wavetrac USA revommended for the diff and lots of others had run 75W 90's too. Thinking about it previous to that I'd only ever run the factory oil 75 monograde and Redline MTL 75W80 and had never had anything as thick as whats in there now. I just cant see how with more or less the same linkage throws and also new synchros I can be running into shift problems, particularly when its hot, so I'm thinking i'll go back to an oil that's thinner when its hot. After a tonne of searching around, lots of guys that track their cars are saying that they just cant fault the factory oil. VW OEM recommended oil is part# G 070 726 A2 which replaces G 055 726 A2. Its $30 a litre. Its Ravenol MTF-3 which is SAE 75W monograde, so I'm going to give that a run.
This all hinges on the theory that what I've been experiencing is a synchro problem and not finding the gear that I'm going for. What happened at wakefield was that the linkage was so weak that when I went for the gear that I couldn't get, the linkage was the weak spot and was jumping out of its track. Once I'd strengthened everything up at SMSP the linkage wasn't coming out anymore, but I was still stuck between gears. This points to the linkage not being the drama, but synchros. However there's no crunch no nothing, just a silent no find of the gear I want?? we'll see.
PS I have a bottle of Redline MTL 75W80 on the shelf that I wont use now that I have the wavetrac as it has friction modifiers in it. If anyone wants it cheap, cash, Sydney let me know. Or if you have a bottle of the factory stuff for a swap we can do that too.
