Picked up these babies today:
The flywheel is a 14lb ECS. It was brand new but I decided to get it refaced lightly cos it had a few tiny spots of surface rust. I was going to get it lightened but most of the advice was to leave it especially considering the near 100km round trip to work I do through Sydneys finest traffic jams.
The box has been rebuilt with all bearings (german ones), new 2nd gear synchro, gears given a clean bill of health, and best of all a Wavetrac. When I went to pick it up he was kind enough to fit the aftermarket pinion brace on the spot which needed a bit of fettling to sit flush and then checked that it had sufficient clearance between itself and the clutch release. The ECS bellhousing scraping tool should arrive before the weekend hopefully so that I can clearance the bellhousing.
So I've got another question. Anyone know the OEM spec gearbox oil grade? I need to order some oil for the box and I just want to check that the wavetrac specified Motul 300 75W90 is the same grade spec as OEM but I cant seem to find anything definitive on the web. The other oil wavetrac recommends is the Motul Competition gear oil for comp use. Its a 75W140 but the gearbox guy cringed at that and said that would be ok in a RWD diff or a FWD box with dog gears but he thought the synchros would struggle with that thickness.
