Originally Posted by
sambb
Gary track is measured across from rim centre to rim centre isn't it. If I got that wrong then my thought process is all wrong on this one. My problem with 215's at the current spacing I use is the extra tyre width and guard clearance. I've had it setup for when I was running the 195 softs and even with the 205's on there its proud of the guard a bit at the front and right out beyond the guard lip at the back. At the back the only thing stopping guard/tyre contact is how stiff it is. So if I run 215's I'm going to have to shift the rims inboard to get the outer face of the tyre somewhere between where the 195's and 205's sit. But if I do that I'm reducing track yeah. I was just wondering if the track width reduction to accommodate the wider rubber (20mm front and back eg 10mm off each side is what is needed) will be detrimental.
That then got me thinking about how I would set the spacers if I run a staggered set up ie 215's on the front and 205's on the back. If track widths are measured rim centre to rim centre, if possible would I aim to set the track widths front and back the same which means the outside of the front tyre will sit wider than the rears. OR do you set it up so that the outside of the tyres line up, which might mean that the rear track is a smidgen wider than the front since the rears tyres are a tad narrower.
So because I'm limited by guard clearances I just wanted to check that 215's will outclass the 205's given the fact that I'll have to reduce track to get them to fit.
Technically wheel track is measured to the centre of the tyre, but for effectiveness on handling it is best thought of as the outside of the tyre.
Personally I just aim for the widest (that's outside of tyre) track possible, front and rear. I have never really noticed a difference between narrower front or rear track. Back in the early FWD days everyone used a narrower rear track, but the FWD Supertourers never went that way, they were mostly the same track front and rear.
The extra contact patch you will gain the from 215's over the 195's (10%) or the 205's (5%) will be far greater than any minor change in track. What's the overall width of your Polo, 1700 mm 'ish? So a 10 mm reduction in track is less than 0.6%, 20 mm is 1.2%. I'll take 10% more contact patch every time thanks.
Gary
