Originally Posted by
sambb
When you press the ESP off button so that it is lit (and the slippery when wet symbol illuminates on the dash) you have defeated the traction control and ironically ESP is alive and well in the background. Pulling the brake switch plug will get rid of the lot though but not inc ABS which will still work. The TC consists of throttle cut at any speed and thrown in below 40km/h it will grab which ever front brake on the wheel which is slipping. It uses the wheel speed sensors to see if a wheel is spinning up and applies a tiny bit of brake to bring that tyre independently back into traction. You cant really feel that happening but you can definitely feel the throttle cut which is so aggressive I reckon its dangerous. So yeah it would be interesting to see what kind of launches would be possible with the TC still engaged, no throttle cut (because its coded out) but some brake modulation happening from a standing start. I've read that brake modulation TC can prevent viscous diffs from working properly since those diffs need a difference in wheel slip speed before they start to lock, but I have absolutely no idea if it would interfere with the locking action of my wavetrac. When traction is very low you can feel a wavetrac switching torque from one wheel to the other and back again. A FWD quaife that I've driven was even worse than that and in a lower torque car so I'm glad I went for the wavetrac version of a torsen diff. But yeah if the TC's brake modulation would make for better launches or help you get the power down coming out of an uphill hairpin then that would be great, or at least you could reserve that setting for when its wet.
