Yeah I think I'm going to go wavetrac over the SQS plate diff. I know that there could be lots of circumstances in that vid that would make them behave differently eg. track temp, tyre temp/wear, leaves on the track, heavier right foot etc etc but it does seems to show enough of a difference between the wavetrac and a normal torsen to justify it. My mate has a quaife in his clio and his does exactly the same thing as the snippet in the video of the quaife if he single wheels it slightly coming out of a corner eg the wheel kick as it sort of grip shifts left and right. If I remember rightly Eddy said his Peloquin did this too. The wavetrac looks like it grips up and just drives out smoother. If a wavetrac looked to be no different to other torsens then I'd have gone with the plate diff and I'd have just worn the risks regarding wear and tear on driveshafts and the clutch packs over time and all the kays I do, but I think the wavetrac will be the best compromise.
Ultimately I'm going to be a sub 250hp car and maybe the plate diff was going to be just over doing it a bit.
In other news my gearbox is with the gearbox guy. Apparently one of the gears is a bit worn which might account for some of the whining so we'll replace that and once the standard diff is removed and we know the ring gear internal diameter, then I can order the wavetrac.
Since my modded K03s is shagged I'll want to get this box in asap to hopefully keep me up there since I may be competing with the standard turbo for a while.
