Page 28 of 190 FirstFirst ... 1826272829303878128 ... LastLast
Results 271 to 280 of 1896
Thread: Sam's build thread
  1. #271
    Apr 2015
    Quote Originally Posted by sambb View Post
    The dampers are an amazing improvement. Despite now probably being overdamped (they are valved/adjusted for 350lb springs but he H&R's are less than 200lb/in) they are like butter over bumps compared to the B8's which are far more crashy in comparison, yet feel great when you lean on them. As a damper comparison on the same rate of spring they are a cut way above. Super motivated now to press on and get the whole lot in.
    You should confirm with Murray but usually he allows enough adjustment in the rebound to handle that sort of spring rate variation (ie; it shouldn't be over damped). When I'm spec'ing a single adjuster shock I aim for a ratio of 3 (rebound) to 1 (bump) ie; 1 click on the adjuster moves the rebound damping X% and the bump damping 1/3 of X%.
    I'm sure you know but 200 lbs/inch is way too soft for an R spec tyre, I'm guessing around double that depending on the movement and leverage ratios between the spring and the wheel. On that subject, I'm sure you are also aware that not being a coil over design there are movement and leverage ratio differences between the shock and the spring as well.
    It is quite common for Bilstein to engineer additional bump valving in the rear shocks of FWD vehicles and often they run higher nitrogen pressure. This helps the handling by supplementing the often too soft rear spring rates.
    Gary
  2. #272
    Nov 2014
    As a ball park the rears on a FWD competition cars should be 50% more than the front per kg of mass, then you look at anti roll bars
    Remember this is wheel rate so you need to multiply the difference between the difference between the pivot to the hub centre vs the spring centre (lever ratio) Struts are as near as damnit a 1:1 ratio
    So for ease of example if you have a 1000kg car with F60/R40 if you have 300 lbs on the front you would want to look at 400lbs on the back
    The classic line for FWD is Shocks are more important on the front while springs are more important on the back! Gross over simplification of course
    200lbs is what you would expect for road based set up, you can't live with SuperTourer style 1000lbs springs every day! Also it isn't good for the average Joe to have a car that wants to oversteer all the time, but as a FWD hillclimber you want to jet the rear rotating so you are using less lock and making the most of the fronts
    (Of course you may decide you can only live with 200 in the back then you may try and do something like add a lot more ARB so at least you get rate on turn, but too much ARB and if your inside wheel hits a curb it will jack up the outside rear mid corner, making it skitty)
  3. #273
    Nov 2014
    Not sure about a much later Polo but toe control on a Mk1 Golf is severely lacking, you can feel the back end move around even a low speeds. Sure toe out the outside rear wheel sounds good for turn in but on high load corners (ie faster) there is more toe, when what you really want is toe out for slow corners (to aid direction change) but toe in for the fast corners for stability at high speeds.
    On track you will lose more time in a fast corner than the slower ones. Not such an issue for hill climbs, but Turn 1 at Eastern Creek or Phillip Island... It isn't the popular set up but stability and drive confidence are worth a lot
  4. #274
    nsw
    'I'm not sure that adding a bolt in the middle would make any difference to the anti roll. It would still link the 2 wheels together with the same overall length. Shortening the overall length is the easiest method, so you could have 3 or 4 bolts, holes and mounts at each end. Just one bolt at each outer end would be the softest setting (longest bar to twist), then 2 bolts (shorter bar to twist), 3 bolts etc. '
    actually yeah I see what you mean by the middle position not doing anything if bolted up since it'd just be twisting with the bar anyway. I really like the idea of the internal beam bar with a pair of mounts at each end if it means that you can run it 'long' or 'short'. Might creak and bang a bit with the inner mounts unbolted though but that'd be ok.
    yeah definitely became aware that 200lb/in was too soft for the softs/mediums that I've run - Just a road reg competitor though so all on a shoe string budget. Yeah the damper mount point is well behind the spring seat and hub position on my car. The damping intricacies that result from that I leave in the capable hands of Josh. I will get on to him re the relationship between bump and rebound and each click setting. I'm guessing he's a tad busy with the WTAC car at the minute though so that one can wait at least until I get the fronts in. As it is the MCA's are 8kg fronts, 6kg rears. He initially wanted me to run 9kg fronts and 8kg rears but with the standard 20mm front bar and no rear bar. When I explained to him that I wanted to run a rear bar (cos I just couldnt see that not happening) he came back and suggested the 8:6kg split. Of the 8:6kg split he said that despite the different motion ratio on the rears that further soften the rear spring rate, that relative to the front and the weight that it is carrying that it is still a rear stiff setup especially when you factor in the rear bar. As it is rear springs are 100 bucks for a set so I can up the rear spring rate cheaply/easily down the track if need be so I was happy to take his lead. He was pretty adamant that I should move away from the whiteline 22mm front bar though and go back to standard, but we both agreed that it was worth trying on soft initially before pulling it out.
    Notsoswift does the spring selection rule of thumb relate to torsion beam rear ended FWD cars just the same as IRS ones too? I only ask because from what I understand torsion beams have significantly higher rear roll centres (and steeper roll axis) than IRS cars which becomes a form of roll stiffness in itself. In your weight split example (if it was for an IRS car) wouldn't you have too much rear bias in a torsion beamed car relative to an IRS car if you threw the same springs at them? just trying to get my head around it based on the bits and pieces of theory that I know. I'll definitely aim to get the springs decided on first, then work out what to do with the front bar and rear toe will come last.
  5. #275
    nsw
    Sam's build thread-img_4894-jpgSam's build thread-img_4898-jpgSam's build thread-img_4897-jpgfront bits
    Sam's build thread-img_4900-jpgSam's build thread-img_4896-jpgrear bits.
    My shiny MCA bits. They run red series 1 way damping adjustment, separate stroke adjustment and height/spring perch adjustment, spherical top mount bearings, adjustable 1 way (camber) top plates, adjustable rear spring seat perches and revised front anti roll bar droplink pick up.. It came with a helper spring for the rears but there's seriously no rear beam droop with the new bushes so I may not even need them.
  6. #276
    Nov 2012
    WA
    Same ones I was thinking of getting
    08 9n3 Polo GTI
    Mods: heaps
  7. #277
    nsw
    I think the X series had been out with the blues previously. Josh has changed the position of the FARB droplink pickup on this new revision . I think mine are the first with that. Its now solid welded to the strut tube rather than a clamp which they apparently used to run. That's just FYI in case you do get them.
  8. #278
    Nov 2012
    WA
    I've got adjustable drop links so should be fine
    08 9n3 Polo GTI
    Mods: heaps
  9. #279
    Jun 2011
    Crap photo and the tube I have at 1000mm is 150mm too long to fit in properly.
    But as a reference. Sit the tube on the lower edge as pictured and put two 20mm welds at each end with an appropriate spacing, 30mm or so.
  10. #280
    nsw
    thanks for that mate. yeah I see what you mean. Is that your pic - are you considering doing the same?
