Page 24 of 190 FirstFirst ... 1422232425263474124 ... LastLast
Results 231 to 240 of 1896
Thread: Sam's build thread
  1. #231
    nsw
    thanks fellas. Sean I was looking at them on ebay but had no way of getting one quick enough. I'll definitely get one for the next bleed. Down at European Autotech they said they basically use them too. I asked about whether or not they use the output test VCDS style of bleeding cos I was worried air might have gotten up inside the ABS distributor. They said they only run that test after a new module has been fitted because there's a risk it can overheat the pump if there's too much air in it and it runs for too long, so I was happy with them just cramming in the fluid from the master cylinder. I have a really good pedal now so the brakes are ready for the rallysprint.
    Yeah my last of headlights I did with a home kit and they came up about 85% and it was a pretty hateful task which I swore I'd never repeat, but I just paid for my MCA's so now I'm skint and will have to eat my words. If I get them half good an acquaintance has a UV heat resistant film (just like a car wrap) that he puts on headlights to keep them in good nick for longer so I might try that this time. My others were smashed to smitherines when I was shunted up the back of the 4WD in the crash so sadly they are gone.
    here's that pic. hope it loads this time.
    Sam's build thread-wtrs_rd4-jpg
  2. #232
    Apr 2015
    For an emergency one man pressure bleeder at a race meeting once I used a spare brake master cylinder cap, grabbed a spare tyre valve stem and fitted it through a hole I drilled in the cap. I used the 12 volt electric tyre pump that I used for quick tyre pressure adjustments, just flick the switch on on the pump while the bleed valve is open. Not for too long as it blows the cap off the master cylinder. Need to refill the master cylinder regularly of course. Total cost = one tyre valve stem.
    Gary
  3. #233
    Apr 2015
    Quote Originally Posted by sambb View Post
    I totally get what you mean regarding positive scrub radius and ripple strips. The first outing with my wavetrac on a tight left uphill hairpin and the steering wheel literally felt trapped at the apex lock that I had on. I had to absolutely muscle the wheel to get it straightened up. The extra drive on the inside front from the LSD and the scrub feedback made it pretty physical compared to what it had been but it was faster that way so I've kept it like that and adapted. From playing around with spacers and going by feel it feels like ET30 is about centre pin steering and then as you start to go outboard from that things start to improve again so I assume ET20 which is what I've run for the last year or so is about 10mm positive scrub - same as factory probably just out the other way.
    I've done the Panorama hillclimb rounds for the last two years and yeah it is pretty daunting - mountain straight is not getting any less scary. The speed that you turn into Griffins bend at and the car going rear light over the crest into Suliman Pk isn't any less scary and I was loosing a tonne of time there chickening out on the throttle. Definitely need a different setup for Bathurst. Problem is my normal setup feels great on day 1 going up the esses where I'm way more competitive so I've tended to leave it alone other than dropping some air out of the rears for the mountain striaght runs. I wonder if a touch of front end toe in on day 2 might make the car a little less reactive too. The other thing I was thinking is that with the coilovers I may be able to play with rear ride height eg drop it at the rear to stabilise it for mountain straight but have it raked slightly for the esses. Thanks for your advice so far. I love hearing from suspension people that do FWD.
    A quick way to check the scrub radius is rub some chalk across the tyre tread, say 50 mm wide. Then lower the car and with just a bit of weight on the tyre turn the steering wheel. Roll the car back and you can see where the centre of rotation of the tyre is, measure from there to the centre of the tyre and that's the scrub radius.
    For the Esses Hillclimb I'd run about 4 mm of toe out (2 mm per side = 4 mm total) on the front and about 6 mm of toe out on the rear, with quite lot of rear antiroll. Without a rear adj swaybar I'd try running the dampers a bit stiffer. I'd also run it with about 10 mm of rake (nose down) to give some more weight transfer onto the front outside tyre. It shouldn't need more than 10 mm but don't be afraid to experiment.
    For the Mt Straight Hillclimb I'd run about 2 mm of toe out (1 mm per side = 2 mm total) on the front and about 4 mm of toe out on the rear, with a bit less rear antiroll. Without a rear adj swaybar I'd try running the dampers a bit softer. Unfortunately you are adjusting bump and rebound together so I would suggest small steps, maybe 2 clicks at a time. If you are finding it still oversteering on the longer, high G force corners then I'd try lowering the rear ride height so that its has zero rake or maybe even a little bit rear down.
    Murray should be able to supply you with a graph of what the damper curves look like, usually the rebound adjustment changes the damping about 2 to 3 times compared to the bump damping.
    Gary
  4. #234
    nsw
    "Murray should be able to supply you with a graph of what the damper curves look like, usually the rebound adjustment changes the damping about 2 to 3 times compared to the bump damping."
    glad you mentioned that because I was wondering if bump/rebound were coupled or not. Yeah I'll ask for sure about what step changes I can expect in each.
    To be honest I've always run the front with zero static toe because coupled with the castor changes and OE ackerman, I had no idea what effect it'd be having as you put the lock on. I was sort of hedging my bets. Rear toe is probably the most conflicting thing I read/hear about within FWD circles. Some say if you are very rear stiff then you don't need toe out at the rear at all and toe in is preferable, others say not beyond zero toe or it becomes treacherous and others say it depends more on your roll axis (what you alluded to). I was reading an article recently that was saying that rear toe has its greatest effect in faster corners because the rear stays more loaded than in tight corners where braking forces have the weight transferring more onto the fronts in the corner - any thoughts on that?
    I can and will experiment on the front but the rear is much harder as it means calipers,discs, stubs-bearing off. I have my eibcah adjusters but I think that might be the last thing after I get used to the new rear and the coilovers and setting them up. I presume that if I adjust my rear static ride height I won't affect the corner weighting to much. From what I've seen of other polo's on the scales the rear cross weights are very even so hopefully that means I can adjust evenly up or down at the back and not be adversely affecting the front.
  5. #235
    Apr 2015
    It's handy to know what the steps are in the adjuster but more importantly the relationship between the bump and rebound adjustments. There is no doubt that Murray knows his stuff but the real question is what has he compromised on to keep the price down?
    Rear toe settings on a FWD car (I always run toe out) are very different to rear toe settings on a RWD car (I always run toe in) and a lot of what we read confuses that. A 4WD (with rear drive primarily) like a Skyline is more RWD in its toe settings whereas Evo's and WRX's (with primarily FWD) are more like a FWD in their settings. Best to ignore anything but specifically FWD when discussing rear toe settings.
    Toe out is what we call an "unstable" condition, it makes the rear end lively, responsive to inputs from the throttle, brakes and steering. Conceptually we run toe out so that the rear is light under brakes and deceleration so that it responds to steering inputs for corner turn in. We want the rear end to step out slightly when there is negative longitudinal G force with steering lock applied, that way it points the front of the car at the corner apex. So we use less steering lock to negotiate any given corner. It also means that we can get on the power earlier as the car is pointed straighter earlier in the corner (we can wind off steering lock sooner).
    As a result I would always suggest running toe out on the rear of a FWD car, the question is how much? Firstly it's driver dependant, some drivers just don't like the nervous/fidgety rear end feeling and it actually slows them down. Other drivers don't even notice it, they just find the car more responsive to their inputs. Secondly it's track dependant, high speed corners with long flowing entries (sustained high lateral G force) aren't the place for lots of rear toe out. Whereas tight corners that demand short sharp entries are prime territory for plenty of rear toe out. Bumpy braking areas are also worthy of respect when it comes to how much rear toe to run.
    To answer your "more effect" question, keeping the above in mind, I would suggest that the best effect (for lots of rear toe out) is in the tighter corners. Whereas the effect of a lot of toe out in higher speed longer corners can be too much, so we reduce it, but I never have run zero or toe in on any circuit in Australia on a FWD car.
    I understand the difficulty in changing toe using the Specialty Products shims, that's why I'd suggest using a mid range toe out (say 2 mm per side = 4 mm) and then trimming out any excessive rear end nervousness by lowering the ride height. Or vice versa. Once you have been to a track you will then know how much toe out you can run. There is no right or wrong technically, a lot comes down to how comfortable/confident the driver feels. If it feels comfortable, cosy and safe then it definitely needs more toe out, if it frightens the crap out of you under brakes then it probably needs less.
    Corner weights wise, in regards to a twist beam, as long as you adjust the pair equally (precisely to the mm) then the corner weights shouldn't change. The first trick is balancing for any permanent twist in the beam, which is tricky. Because adjusting the spring seat heights (to achieve corner weight balance) maybe introducing a twist in the beam, hence preload in the anti roll. My suggestion would be set the spring seat heights the same on the rear (to achieve the desired ride height) and then use the front spring seat heights to achieve the diagonal balance. That will minimise the preload in the twist beam and avoid any uneven anti roll.
    Gary
  6. #236
    nsw
    Thanks for the response Gary. You managed to answer pretty much everything I was wondering about so thanks very much for taking an interest in the setup and offering your ideas. The tracks in the state hillclimbs and the rally sprints are all very tight point and shoot sorts of circuits so rear toe out looks to be the way to go. I'll just have to trim the rear with tyre pressure, ride height and the damping when doing the fast stuff. Next step I guess is to get it aligned and see where each rear wheel is pointing andindividually set them up from there for the right angles. It has static 1.5 degrees negative camber which I'll probably leave in place. thanks mate.
  7. #237
    nsw
    Sam's build thread-img_4758-jpgSam's build thread-img_4782-jpgSam's build thread-img_4804-jpg
    I've had the front off the car primarily so that I could get the bumper off and nuts welded onto the back of it in locations where I can easily run bolts through from the front to mount my nudge bar and spottie for the twilight rallysprints that are coming up. While I was at it I decided to plumb up a cabin actuated intercooler water spray. Onmy last car the water spray was manual and boost activated. Now that I have a proper sized front mount the water spray whilst underway is not that critical but its still a big benefit to have a water spray to chill the IC down prior to a hillclimb run especially if you have the AC on with the fans running at the same time. It makes for a very chilly IC off the line and would also work very well for drag folk. So what I did was pop off the rear wiper fitting off the wiper reservoir pump (its the one on the inside). Cut the pipe about an inch up from the fitting. I basically then just plumbed in a Y -piece with it angled/biased towards the IC. If you use silicon 4mm tubing it just push fits over the ribbed wiper tubing that you cut and is secure and will not leak. I ran a test and even though you are now activating two nozzles, there is tonnes of pressure at the new nozzle head. I haven't got the IC nozzles in place yet. My old SMIC nozzle doesn't work at close range very well on the tall SEAT sport IC. I tried some irrigation fittings (1/2 and 1/4 circle) and neither of them gave good coverage either, so i'll suss out what the EVO's use ad go from there down the track.
  8. #238
    nsw
    Sam's build thread-img_4806-jpgSam's build thread-img_4813-jpgSam's build thread-img_4814-jpg
    So when I had the bumper off, as well as getting the nuts welded into the back, I angle ground the top upturned lip off the top edge of the bumper. I did this so that air getting through a cut out I made would run straight onto the core rather than hit the lip and be deflected upwards and also so that the boost piping which was sitting very close to the sharp edge of the bumper would be safe. I'm glad I did de-lip it because the cutout location was bang on and will let a tonne of extra air straight onto the core when I run in hillclimbs without the number plate or nudge bar.
    Attached Thumbnails Attached Thumbnails Sam's build thread-img_4827-jpg
  9. #239
    nsw
    Sam's build thread-img_4819-jpgSam's build thread-img_4820-jpgSam's build thread-img_4821-jpgSam's build thread-img_4823-jpgSam's build thread-inkedimg_4829_li-jpg
    While I was in there I also made up a CAI feed. If you just take some tin snips you can put in two cuts on either side of the flap that sits under the mouth and then just flex the flap up and down and it will break free cleanly. There's a ready made slope built into the mouth that lets you just drill some self tapers into the radiator support and mount whatever shaped feed you make. Mine is 175mm wide at the front narrowing to 145mm at the top and the edges are folded up at a height that allows it all to tuck in under the slats when the grille is fitted. It basically picks off air that otherwise sails straight over the top of the radiator through a void and into the engine bay and channels it up. It'll also prevent the CAI sucking air straight off the top of the radiator in traffic or at hillclimbs/drags after queueing up. To finish I taped up the slits moulded into the panel above the CAI since it'll just let pressurised air running up the ramp towards the mouth to escape out the top and across the underside of the bonnet.
    Main thing is when the number plate is back on you wouldn't know anything had happened.
  10. #240
    Apr 2015
    I've probably given you enough to think about already, but just one more......
    With twist beam rear suspension the roll centre changes according to the angle of the trailing arm. A trailing arm that is, say, parallel to the ground has a higher roll centre than one where the trailing arm points downwards towards the wheel. As a result changing the ride height (RH), which obviously changes the centre of gravity (CoG), also changes the roll centre (CoR). The CoG moves 100% with the RH but the CoR moves around 40% on a Polo (from memory). ie; lower the car 10 mm and the CoG moves down 10 mm but the CoR only moves 4 mm. Hence when we lower it we reduce the roll couple (RC) by 60% (ie; 6 mm). Conversely if we raise the RH 10 mm the RC increases by 6 mm.
    As a result of all 3 (CoG, CoR and RC) changing at once ride height changes are a very powerful handling tuning tool, it's a big hammer so don't hit it too hard. A few mm at a time and feel for the effect.
    Hope to catch up at a hillclimb sometime next year
    Gary
