Being able to adjust the A/F ratio (roughly) via the FPR is a help where the ECU tuning has limitations. For example, on the Stagea the ECU runs the engine but comms to the ECU for the auto gear box and the ATTESA ECU for the 4WD. So there are limitation built in to the ECU firmware to prevent overloading the gearbox etc, such as maximum injector duty cycles are various RPM points for torque limitation. I used the adj FPR so I don't exceed the duty cycle limits. Then tuned around that. Otherwise you get stuck at 180 4WKW, whereas I've maxed out the injectors (80%) at 220 4WKW without tripping the load limitations.
Gary
