Originally Posted by
sambb
So Gary do you think the fact that one side at 20 degrees out had a touch more camber than the other wheel at the same angle is likely just that I wasn't able to transfer the 20 degree lines exactly onto the ground (or line the wheels accurately with them)? That's what I'm hoping. Because at the end of the day the formulas pumped out the same final caster numbers for both sides.
It could be any number of things, it's not something that I'd stress over.
Yep I've done a bit of oil squirter research and yes it does turn out that the squirters vary. Some are longer and the orifice is smaller ( I assume that would limit peak flow but squirt stronger at low rpm) and others are a much bigger. I think the safest thing to do would be to find out what BAM 1.8T 20V squirters look like since i'll be running that wrist pin size with that piston.
Nissan uses a small oil feed exit hole in the squirter, that's what controls the oil flow. From memory around 1 mm, so I used a 1.1 mm drill to increase the flow as the longer stroke RB30 revs lower than the shorter stroke RB26, so I wasn't worried about over oiling at high rpm. The oil squirters themselves are all the same part number. If the VW ones are different then choosing the one that matches the gudgeons is logical, just be aware that they may change due to the crankshaft stoke and/or shape. Also some engines have pistons with a cut out in the skirt to clear the squirter at BTC, so best to check that on assembly. On the RB I used a copper washer to space the squirter down enough to clear the piston skirt.
Gary
