They are a good rotor, I'd stick with them. Pretty decent size at 355 mm x 32 mm they should work very well. I'd put the wear down to the endurance compound pads, they don't wear (as fast) so the rotor cops it.
Hawk list lots of Wilwood calipers (pretty much every one ever made), you just look up the caliper brand and type and it will list the available pads.
Parts Lookup | Hawk Performance
Wilwood BP10 is pretty much a heavy duty street compound, would be OK for hillclimbs, supersprints, time attack etc but not suitable for 15/20 minute track day sessions, the heat build up would be too much for them to handle. Polymatrix A are similar to Hawk HT10 and would be an OK choice for you to try.
As I posted above, Hawk Blacks are my go to pad for performance and value for money. They also serve as a useful base line, I often use them in cars/drivers where I am not sure what they need. Then after a few sessions I get feedback, download the data etc and I then can make a call on which direction to go. For example, in a car with little to no downforce, if they creep up on the brakes then I can use a DTC70 or maybe even a DTC50 at a stretch. But if they have a slam on the brakes style then DTC70 would be a step too far. More suitable would be HT10 or DTC60 at the highest initial bight. Caution, Hawk Blues are an endurance compound, stay away from them for your purposes.
No Problem, happy to help anytime.
Gary
