18-07-2019, 10:09 PM
#1531
hey Sam - don't throw away the compressor! I think mine has started making noises
18-07-2019, 11:06 PM
#1532
ah sweet. Thats the one I did years ago. I love how the re entry into the course at the bottom is actually a pretty damn fast corner. First time I did it I was caught out at turn 2 because the second time you arrive there you are doing triple the speed and I got my braking point muddled. Those trees on the outside of that bottom sweeper are dodgy though I reckon. I wouldn't want to go off there in an open wheeler. I'm pumped. We only ever get 4 runs at the state events usually so why not make them two laps. Might need to actually take a little jerry can!
18-07-2019, 11:07 PM
#1533
You're welcome to it Simon. I'll seal it up while its still got the gas/lube inside it. Let me know when you want it.
18-07-2019, 11:25 PM
#1534
Yeh, it's a fun layout! Do you know what time you did last time? Not that I guess it's relevant with everything you've done to the car since.
19-07-2019, 12:53 PM
#1535
Slow. 62 seconds I think. It was torrential rain and I was on reoo3's and it was the second time I'd been there so yeah, I won't really know what to expect from it. What time did you do in that vid? That should be a good guide. Looked like a tidy run.
19-07-2019, 01:50 PM
#1536
Ah right. Don't think it was 62s though... The vid above was a 75.36. Was my third run and I probably would have gone quicker but I had some mechanical dramas. Here's the results from that event to give you some comparison against other cars, it was a tri-challenge hillclimb.
19-07-2019, 06:48 PM
#1537
ha ha yeah definitely not 62's then. Might even have been 92's given that it was monsoon. Alright 75's. Think i'll run the softs on the back again. I still don't think even two laps there is enough to get any heat into the rear of a FWD. It'll be first time for me so not too concerned with times, I just want it to be close. That last state event when the top 6 were within 0.5 sec was unreal.
20-07-2019, 02:58 PM
#1538
too easy with the right tools:
YouTube
20-07-2019, 06:28 PM
#1539
I should have the AO50s on by then... It'll be interesting to see how they compare!
20-07-2019, 06:49 PM
#1540
Look out, youll be fast on them! Softs or mediums?
- You may not post replies
- You may not edit your posts
Forum Rules
