Quick comments, small stuff, nothing major, no need for self deprecation, you were way better than most;
Later apexes on almost every corner, make the straights longer.
Steering wheel should be straightening on approaching the apex, not still turning.
Apply power as soon as you start straightening up the steering (more power as lock decreases), more power means less understeer.
You should be at full throttle at the apex for most corners.
Turn 1 you need to be much more hungry on the bread roll strip, over it, inside it, use it to hold the line, it will help with turn 2 which is currently being compromised and thus affecting speed up the hill. Same with ripple strips, if there is flat concrete inside of them use it.
I need to look at in some more on the big screen to see what is happening suspension wise.
Gary
