Page 114 of 190 FirstFirst ... 1464104112113114115116124164 ... LastLast
Results 1,131 to 1,140 of 1896
Thread: Sam's build thread
  1. #1131
    Sep 2006
    I did it so long ago I cant remember
    Double up 2 nuts together so you can tighten them in properly, i used a heat resistant loctite and have not had a problem for 5 years
    MODS- TOO MANY
  2. #1132
    nsw
    yeah thats it. I'm mostly worried about the threads in the hub. The spec for the wheel bolts is 100Nm I think but I doubt I've ever done them up that tight on the well used threads. I just do them by feel with a breaker bar and check them throughout the day when I'm tracking. The threads have had a bit of a hiding with lots of in out in out over the years which is what has concerned me re the tightening torque. I always thought you just did them spark plug tight (provided they have the ridge bit to butt up against). My mate in his Clio did it that way and they havent come out with the rattle gun. Guess I can just split the difference between 100nm and the sellers 35Nm and do about 70Nm which shouldnt go wrong with the right Loctite.
    I think all up with postage it was 175 bucks - thats with two sets of nuts which aint bad. That was the main reason why I bought from OS. The nuts were basically free with the studs compared to over here where the prices for nuts seemed ridiculous.
    I got your 3/8in spacers in at the back Simon. Only had to file the rear beam a bit on the left side to make way for the ABS sensor but otherwise easy as. The longest time in all of it was deciding on which angle settings and fitting the eibach shims. My right rear was already at 2 degrees neg camber and -1.7mm toe out. The left rear was 1.6 degrees neg camber and -0.7mm toe out, so I basically aimed to square up the left with the right.
    I'd been tape measuring the rear toe at approx. 2mm toe out total but obviously it wasn't even on each side.
    So the aim is about -3.6mm total toe out (even on each side this time!) and 2 degrees neg at the rear. I had noticed that the car was far better turning left compared to right and I'd say that was why - it was hooking around corners on a nice amount of right rear toe out and less so on the left rear, and it could really be felt. That's why I tackled the subframes recently because I was sure it was due to a misalignment there, but nope it was rear toe. Starting to learn that rear toe (other than a rear bar) is king at determining the extent to which the car WANTS to turn. I haven't been back down to the aligner I use to verify the result yet but the car does feel very very nice now. Its going to kill the inside edges of the rears like that but when it wants to turn like it does now and understeer is not really something I even think about on the street anymore, then its well worth it. That's partly why I stayed on 195/55/15's just to keep the price of tyres way down as I'll be going through them that's for sure.
  3. #1133
    Apr 2015
    Quote Originally Posted by sambb View Post
    Yes, it is
    For DIY (warning this is going to take me longer to type and for your to read than it actually takes to do), you need 4 axle stands, 2 pieces of 25 mm box section alloy around 2 metres is plenty and some hat elastic (better than string). Mark the centre of the alloy box section, set the axle stands at the height of the centre of the wheels and put them just behind and in front, roughly in line with the headlights and tail lights. Place the box sections on the axle stands lining up the middle of them with the middle of the car. Measure between the box sections to make sure that they are parallel. Run the hat elastic down both sides of the car and tie each end to the box sections. Measure from the centre of the rear wheels to the hat elastic and equalise it by moving the hat elastic on the box section, do the same with the front wheels. Check by measuring the distance the hat elastic is in from the ends of the alloy box section, should be the same distance so that you have a right angled oblong (then mark the locations on the box sections for next time). Measure from the extremities (front and rear) of the wheel rim to the hat elastic. Duplicate on the other side, added together that's your total toe. Check it with your toe plates.
    Warned you it would take longer to type/read than do.
    Gary
  4. #1134
    nsw
    yeah that's the next thing to nail. My front toe was correct for total mm too - bang on what I'd set it at but looking left. Actually the only reason I went to the aligner is because the RE003's aren't as baggy on the rims as the R1R's and so the toe plates I'd made were actually resting on the rims rather than the tyres themselves and were shifting a bit when I was measuring and I couldn't get repeatable numbers. Good thing I went, so yeah, I'll get that sorted.
  5. #1135
    Apr 2015
    Front toe, side to side, doesn't matter as you just turn the steering wheel to equalise. Of course it can be annoying to have an off centre steering wheel, drives some people nuts.
    So when adjusting front toe I always adjust both tie rods the same amount, keeps the steering wheel straight.
    Gary
  6. #1136
    nsw
    ha ha yep it drives me insane when its one hand down. On the older cars you could just reposition the steering wheel 1 or 2 splines around if you were lazy but not possible with the VW steering wheel! Strangely I dont mind right hand down but left hand down does my head in.
  7. #1137
    nsw
    Sam's build thread-img_6785-jpgSam's build thread-img_6788-jpg
    Wheel stud conversion done. Ended up doing 45Nm as that was all the 5mm hex key was going to. Cleaned all the threads spick and span and used some Loctite and then torqued the nuts up to the spec factory wheel bolt setting of 120Nm! so it can all cure. I'll rattle them off tomorrow and make sure nothing budges. Makes wheels on off SOooo much easier so fitting rims, spacers etc at the track should go a hell of a lot quicker/easier now.
  8. #1138
    nsw
    Sam's build thread-img_6813-jpg
    Front camber basically a shade under 3 degrees neg (more on the left front for Wakefield and Ludenham) and a shade under 6 degrees pos. caster. Total toe out of 2mm. That means I'm only 1 degree shy of the magic 10 degrees total number, so pretty happy with where all that's at.
    Sam's build thread-al-2-jpg
    Rear ended up a bit annoying. With the shims I'd added some neg camber to the left to square it with the right with a touch extra to both sides to try to arrive on 2 degrees neg camber from the 1.75 dgrees I was on. I finished up equal on both sides which was great but despite adding additional camber with the shims ended up on only a touch more camber than before! Same deal with the toe out. I'd previously had 2mm total toe out but was off left/right so I adjusted the shims to square them up and add a little more to try to get 3mm total. Again for some reason I ended up more or less square but didn't gain any toe, even went backwards a bit.
    I did all this in conjunction with adding the 9.56mm spacers to each side so if that somehow changed the kinematics I don't know. Same alignment place, same tyres/pressures so not sure. At the end of the day those rear numbers are still pretty good and considering that no significant extra camber went on then I'm ok with the toe where it is for now. Don't have the stomach to tackle it all again right away so will just drive it and see how it goes. After all I have changed from the 22mm front bar back to the factory 20mm and I wouldn't mind assessing that on its own on the track now anyway.
    Other than sorting a baffled sump (which is proving impossible to do without spending an arm and a leg) and doing something with harness/seat, I'm now pretty well done with big list things to do to the car. Just some fiddly things to do eg front anti roll bar bushes if I decide to stay with that bar, maybe an IC re jig, mucking around with rear spacers to get the track widths correct front:back with the track rims etc but more or less the car is now pretty well sorted and just ready to drive. Still cant get it out of my head to try and top Eddy at Wakefield but with a K03 and will pursue a class win in the State Hillclimbs probably until I crash the thing, so those are the aims for the year ahead.
    edit: not the crashing bit!!
  9. #1139
    Jun 2017
    Newcastle, NSW
    Haha, not aiming for a crash? Going to come up for the last club hillclimb at Ringwood for the year on the 4th of November?
  10. #1140
    nsw
    I'll have a look - I'd like too. How'd you go at Mattara?
