Thanks for that Gav! Or maybe my check engine light globe is busted![]()
You would get different codes is the vac valves were disconnected for sure, and like i mentioned before the ecu does request the sai pump during cruise or even hot idle. Gav before 05 the ECU wont even trigger a CEL if you just leave the pump off but if you scan it the oncorrecT flow code will be there, but tighter emissions with ECU after 05 will in fact bring it on even though the engine runs well, my issue with that is other codes will get hidden if just left alone. Anyway great to hear the custom stuff can switch it off, thought as much, but im trying something else that has been overseen with most as ive read, not giving it away just yet, still if it doesnt work then Kevs gonna be a busy man!!!
Jmac
Alba European
Busy? mental as it is man, anyway must add i had an 03 2.4 BDV engined A4 that ended up getting an older 2.8 engine there fore the original stuff had sai and the old engine doesnt, it still runs 03 software therefore has all the codes as the pump is bleeding into mid air through a filter but no CEl, on an 03, i have no doubt if it was a b7 done the same way it would have a light.
Anyway stay tuned to see if my idea worx for the ones not getting it mapped out.
Im doing it tmw as today was SERIOUSLY off the charts.
Car will be in the traffic over xmas and that will be the acid test
Jmac
Alba European
Have done the repair and have driven the machine around for a while but as most know it can be days before the CEL appears, car going back to the customer to try and will report back , will give it a week or 2 in the traffic.
Fingers crossed, oh and FYI this car is running APR software
Dont really want to give anything away just yet just incase, but if it works there has been a right and wrong , thats all ill say for now
cheers
Jmac
Alba European
good to hear Jimmy, keep us informed.
2016 MY17 Polo GTI with DA package. TMD fitted + Weather strip and Snow Screen removed otherwise dead standard.
Did the super dooper secret trick work?
Any progress fellas?
