Its been pretty cold driving home at night in Sydney lately eg 5-8 degree nights, and I've noticed that if I get the heater on as soon as hot air will come out, that the cluster engine temp gauge wont make it to 90 degrees. It'll park itself on 70.If I turn the heater off again the temp will get up to its normal zone though. Throughout this the car is in 4th and 5th gear cruising.
I didn't think much of it as it was very cold, but this afternoon I decided to have a look in VCDS on the way to work. It was 12-15 degrees (so warmer) and there was a fair bit of traffic to keep the temps up. The VCDS temps at normal operating temps agreed with the cluster gauge so I think that gives the coolant temp sensor a clean bill of health. But sure enough if I was at normal operating temp on the cluster (90 degrees), if I put the heater on full heat/speed the VCDS temp went from 90 degrees down to 68 degrees! and the needle nearly got down to the 50 degree mark on the cluster.
SO .... is that normal? I've only had this car for one winter and was building the thing throughout and I cant actually remember how it behaved in the cold last year. Surely the heater wouldn't have that big an effect. I'm thinking the thermostat is suck open. thoughts......
