Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: SAI and N249 Removal
  1. #51
    Jul 2010
    Thanks, yeh will do. Just dont want any water getting into the pump which would cost more $ to replace than a hose.
    Fingers crossed its just a loose/cracked hose or something similar.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
  2. #52
    Mar 2007
    Gold Coast
    I was quoted $790 by VW for a replacement SAI pump. Fortunately it doesn't do anything too important.
  3. #53
    Jan 2009
    blankedy
    I did the easy part of this today, removed the VAC system, used the IE plugs.
    Went to block off the SAI at the combi-valve, didn't fit...
    Left the SAI pump in place, pipes where they are and used the IE resistor to eliminate the flow.
    So far so good, I'll wait a few weeks to see if I get a code. Car feels a little torqier, but could be a placebo. Certainly wasn't any worse on startup.
  4. #54
    Nov 2008
    Canberra
    I did this last week. The forge mk4 (2 hole) blanking plate will fit on the top of the combi valve tower - replacing the valve - if you file the bolt holes in the tower a bit bigger. Made a new gasket out of silicone sheet. Works well and looks good and no loss of coolant.
  5. #55
    Jan 2009
    blankedy
    That was a pain to access (with my tools), so I've left the pump i place for the time.
    Starting to think my pump or combi was dying, the car is much quieter ad smoother on start up now. Its been a week, daily driving and no code yet (some magic in those IE resistors).
    Jmac, when I go to do the block off, where should I clamp to stop the excessive fluid loss? Car will be on jacks.
  6. #56
    May 2011
    I'm now getting a CEL for the SAI with error code P4011.
    If I go ahead and remove the SAI and combi, will I have any issues with Insurance or roadworthy down the line?
    I honestly just want the light gone, and the though of $$$ for my mechanic to troubleshoot it more (popped up 2 months back) or replace the pump is not something I really want to deal with now.
    2008 Polo GTI, lower honeycomb grills, PD160.
  7. #57
    Jan 2009
    blankedy
    Removing may not stop the code appearing. At this stage there is no universal solution to the issue.
  8. #58
    From what I've seen everyone who's done the emissions delete overseas with compulsory emissions testing has passed.
    I can't see it being a big issue re roadworthy, unless they know what they're looking for in the bay?
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  9. #59
    May 2011
    Quote Originally Posted by spraycanmansam View Post
    Sounds good. I'll look into having my mechanic check the area again to see if it's a busted pump/hoses/clogged valve etc. Then depending on cost, look into getting it all deleted.
