Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 59
Thread: SAI and N249 Removal
  1. #31
    Jan 2009
    blankedy
    Blanking plate collected today.
    So it seems the N75 uses the boost pressure to control the n75, so I should be fine to leave that connected (don't think the Vac system will affect this).
    So if i remove the VAC system, I'm affecting:
    N249 (bypassed)
    SAI (removing)
    Diverter (running from manifold)
    What else? There are lots of guides, but seem to be for Audi's and mk4's, so slightly different..
  2. #32
    Nov 2008
    Canberra
    Any chance of pictures as you proceed with this - for we who follow.......................?!
  3. #33
    Jan 2009
    blankedy
    Sure, no worries. Looking to start next weekend, assuming I have all the little bits and knowledge sorted by then.
  4. #34
    Jan 2009
    blankedy
    Did the SAI removal today. Was a good little project. Boost has changed and car has been a little jerky, my a/f ratios have changed, have not had a chance to let it settle, I was not really expecting any change in that department.
    No issues yet, normal startup was fine after blanking. Will hack together a diy later. Need to clock up a few k's to get the boost under control again.
  5. #35
    Jul 2007
    Auckland, NZ
    thanks noone, interesting topic
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
  6. #36
    Jan 2009
    blankedy
    For anyone wanting to see a DIY, I used this one from SeatCupra.Net
    The thread is a little brief about some of the details, but is based on the same engine.
    The bypass is pretty simple over all, I'm using 10W, 30 Ohm resistors for the time.
    Basically, the process goes:
    - Remove the Air intake section or PD160 to the airbox.
    - Remove the Coolant connection on the side of the engine block (you loose a fair amount of coolant, so use something under there to collect as much as possible). This allows access to the 3rd screw to remove the combi valve.
    - Remove the Combi Valve (not as shown in the guide, from the side of engine mount).
    - Use blanking plate (eg Forge) to blank of SAI.
    - Remove the Pump (under manifold) - (for its size, its quite easy to remove with the air intake piping out of the way. Only 3 bolts holding in position.
    - Remove Vac reservoir, N112 and N249 from on top of the engine block.
    - Plum Diverter vac direct to available var port from manifold.
    - Use resistors in place of 3 electrical connections (N249, N112 and Pump).
    - Refill Coolant
    - Reattach all connections that may have been removed
    - Plug the hole in the Airbox (assuming you have one). I made a disc out of plastic, used elec tape and cable ties to secure.
    This is not a complete DIY, more a comment to the Seat forum one which is the most relevant as its based on the BJX engine, not an AGU, or other variant that requires more work.
  7. #37
    Dec 2008
    Curitiba/PR, Brazil
    Some pics to ilustrate the topic.
    SILVER TEAM
  8. #38
    Jan 2009
    blankedy
    Thanks Plautos.
    So after not much driving, but a few trips around, there seems to be a little more boost (i'm sure the ECU will suck this out again once its settled).
    I have thrown 1 code: Secondary air flow. Not concerned, its not affecting the vehicle in any way I can tell, cold starts sound much the same, no dash lights.
    for the time, I'm calling this a win.
  9. #39
    Jan 2009
    blankedy
    A few photos:
    This is most of the hardware that came out when removing the SAI system
    Here is the airbox plugged. For the time i cut a plastic disk and taped it over the hole, securing the tape with cable ties.
    I've reused the N112 as shown on the left as the resistor for that device was throwing a code. I will solder the correct resistor into all the cables down the track if I keep it all this way (so I bit of a temp setup whilst I've been testing the system). The other item is the MBC as per a different thread.
    Here is the combi valve before taken out. To get to the bottom of the connection, the coolant line had to be removed. I lost over a liter of coolant whilst removing the combi valve.
    Here is the space where the SAI pump used to be. Was fairly easy to remove with the intake hose out, surprising for how large it is.
    Looks like it will stay this way, only 1 code when scanned for incorrect flow from SAI, no issues, no rough idle, no problems to date.
  10. #40
    Jul 2010
    Nice foot
