Originally Posted by
h100vw
I could do as, I have a Polo but all 1.8Ts of that era are the same make up.
The worst part, if there is one is that you need to partially drain the cooling system to fit the blank. One of the bolts that holds the combi valve tower is right behind a water outlet on the side of the head.
That's probably the worst part. I did one in the street outside my house a while back for ST165.
There's a drain tap on the radiator on the passenger side. Drop the coolant into washing up bowl, ask your mum first, then you can reuse it. I do this as there's no where local, to dispose of it in an environmentally way.
You need an odd 13mm nut to retain the dipstick tube bracket. I can dig one out for that and send it too.
