Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Thread: SAI / 249 Bypass - guide
  1. #31
    Yeah I dunno hey... most emissions delete's I've seen disconnect it and just run a line straight to the booster.
    Just thought I'd add that I recently got sick of waiting for my resistors (2 months!) and popped over to Jaycar.
    If you go down this route you'll need 1W x 330Ohm for each of the solenoids (N249, N112, etc) and I'd recommend a 10W x 400Ohm or more for the SAI pump.
    I just bent the connectors and pushed them into the connectors and taped them up, no need for spade terminals, etc. Cost me all of $2.
    Before I put the 470Ohm resistor in the pump I would get a CEL the next day after clearing. 2 days on now and no CEL, touch wood.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  2. #32
    Feb 2007
    Brisvegas
    In addition to what Sam said I'm up to 20000kms now with no CEL.
    This is a cut and paste of mine from another thread regarding this;
    Hey mate in regards to the CEL, I remember now what I did to erase the issue once and for all. I threw a code at about 500kms after the delete because I stupidly bought 1 oval and 1 square resistor so had to go to Jaycar to get one of the bare resistors (like the one IE sell for the SAI pump) to go on while I waited for a another round one.
    He didn't have a 330 ohm resister so he piggybacked 2 smaller ones which gave a total resistance of about 400 ohms from memory (or maybe a little less) anyway it seems 330 is too little and will through a code. But a bit more resistance does the trick and I have not had a CEL for over 15,000kms
  3. #33
    Aug 2007
    On top of all that i agree you dont have to wait for the IE ones , granted the valve ones are very tidy. On the SAI pump i find to make it very tidy is to cut the actual plug off the pump ( you are chucking the piece of sh1 away anyway) and tidily solder the resistors onto that plug then simply plug it into the engine bay loom, way better than what ive seen , sorry dont like just sticking male spades into connectors, its untidy for me anyway but most kjnow of my OCD lol. i would rather it look like its meant to be there.
    Thats my take , each to their own, its your car. By the way not in any way being negative here just merely giving a tip and my take
    Cheers guys
    Jmac
    ps next one i do ill take a pic, which will be in the next couple of days anyway.
    Alba European
  4. #34
    Oct 2012
    Northern Ireland
    Going to delete my PVC system at the weekend. Along with moving some other vacuum pipes, going to be a trial and error process. I'l keep you posted
  5. #35
    Mar 2012
    NSW & Romania
    Just went through with the delete today
    Yet to drive it but will let everyone know how it goes and if I throw a code.
    The stuff ontop (#1 & #3) is simple. I tried to put the blanking plate ontop of the vertical shaft rather than loosing coolant - took almost 2 hours fiddling to get the combi valve unbolted only to find the bolt spacing is different (IE Blockoff Plate) and so had to unbold from below anyway!
    I found I didn't need to take off the coolant attachment, just loosened the two nuts ever so slightly and could then get in to the upper bolt of the combi valve shaft.
    Its all connected back up, still have to do the SAI pump resistor, will probably go down Jmac's recommendation just above and heatshrink it all.
    Red 2006 Polo GTi : Forge Splitter - TIP - ITB - Forge Front & Rear Strut Bars - Dash Cubby - Fumoto Valve - Full Milltek Exhaust - PD160 Intake - K&N Panel - ECS Stage 1 Clutch - Seat RCA Bushes - APR Stage 1+
  6. #36
    Jan 2009
    blankedy
    Cool. Don't be surprised if it throws a code with resistors.
  7. #37
    Hi All
    Could someone please clarify, this is a tidy the engine vs a performance mod?
    Sorry for the nub question
    ~graham
  8. #38
    Quote Originally Posted by DUB80Y View Post
    Hi All
    ~graham
    This is a don't spend $700 on a new air pump mod. However, you will need get a fault code come up if you don't have a tune specifically to cancel it.
    The ECU knows it has requested the pump to switch on, but doesn't see the expected change in the exhaust.
    I have some blanks for $20 delivered, which can use the standard bolts. This removes the combi valve tower and goes on the side of the head.
  9. #39
    Jun 2007
    Reading through the past posts, is the culprit the combi valve? My car is developing the issue but not to the point of throwing codes. I am looking at options to fix/remove it. Unfortunately, GIAC don't do a code to remove it the SAI. I can get the parts from O/S for the pump and combi valve for about 750 at the moment. Either way, it's quite expensive.
  10. #40
    Jan 2009
    blankedy
    Mine is low ks, happy to sell to keep you moving.
