Originally Posted by
AntiFun
I read your forum post about the issue Jmac, very good stuff, thank you very much
The code wasnt p0441, it was p0411, very similar!!! It said incorrect airflow detected.
I guess my picture demonstrates how moisture gets into the system
Man those codes are very similiar!! and are both flow codes relating to different systems, crazy, ok then forget checking the canister valve its all about SAI, the kombi valve and gasket. experience has shown now that the actual fault code has to be written off the table in the eeprom and resistors wont help. You can simply switch the pump off but will have a MIL lamp and problem i have with that is you wont get to see an importatnt one if it arises so best to resolve it
Good luck
Jmac
Alba European
