Results 1 to 10 of 20
Thread: Rust in Airbox + Bonus P0411 Code.
    Mar 2013
    Melbourne, Victoria, Australia
    Hey guys,
    Haven't written up an intro thread properly yet (made one about servicing . . .) but I picked up my 9n3 about a week ago now. It's the one formerly owned by "jigme". Car has a apr v2 tune, exhaust (muffler only I presume), springs, apr diverter valve, seat intake....
    Car's been fine, Been loving it... But it developed a backfire when I first picked it up. Didn't think anything of it, Jigme warned me that the car needs a tune for the exhaust, which is fine because I figured I'd get that done and get the timing belt done at the same time...
    Yesterday the car threw a CEL, no performance changes, no limp mode either. I checked the code today with the help of a friend, turned out to be P0411, after googling around a bit it, I should be looking for vac leaks and broken hoses relating to the emissions system....
    I opened the airbox, and the whole thing was full of orange rust dust. I have no idea where it's coming from... I had to pull off a tube that connects to the top of the airbox before the MAF and that tube was full of rust aswell.....
    Any thoughts guys? What should I do from here. The car drives fine as well as far as I can tell... Is it possible that the rust is coming from this tube? or doesn't the air flow that way? The filter is supposedly aftermarket as well, I guess there might be a possibility its the filter itself that developed the rust?
    Currently I'm thinking I need to, clean the MAF, check the hoses post the MAF, clean all the orange dust... Don't know what to do next about the p0411 though... I have a feeling that the air filter might have rusted, and that the rusty dust has got into whatever that hose leads to that is after the filter but before the maf, which has caused the p0411? Someone please educate me if I'm wrong...
    Jan 2009
    blankedy
    you sure its rust? are you in Sydney? the reason I ask is that 18 months ago there was a terrible dust storm, red dust everywhere.
    The code could relate to your SAI pump / valve being spent / on the way out, fair few of them going that way.
    Can't think of where rust would come from, its almost all plastic around there, accept from the SAI pump... pull off the flexi pipe coming from the front of the engine to the airbox, full of the rust / dust?
    Mar 2013
    I suspect it's the air filter as it didn't look like a paper filter, will get some pics in a minute. The walls of the air filter box after and before the filter are covered in orange. You can wipe the orange off with a finger... Orange like rust, has to be rust.
    Ok, so I think we're describing the same thing, The SAI pump has a hose running from it into the airbox, after the filter but before the maf.
    Feb 2007
    Brisvegas
    Welcome mate! Rust, that sucks. I wonder if water has gotten into you secondary air pump (emissions related) rusted it up and blown that into the airbox. It's a long shot but water in the pump is very common as Jmac will tell you. Or as noone said it could be an ass load of red dust.
    Feb 2007
    Brisvegas
    Quote Originally Posted by AntiFun View Post
    Yep, that's the one.
    Mar 2013
    Can I disconnect the hose and block it off for a temp fix? Or is there a plug for the SAI I can unplug at least?
    Aug 2007
    The p0441 one is the imfamous evap code that can happen to any car, i would bet the Charcoal valve is sticking, it can be tested by VCDS in final control diagnosis, if its clicking very queitly itll be needing replaced.
    Jmac
    Alba European
    Mar 2013
    Jmac, should I be concerned of damage to the engine? Do you think I can keep running the car if I disconnect the hose? or is this an urgent straight to the mechanic thing?
    Thanks for the welcome VWindahouse
    Ok this is what I've found Secondary air pump problems
    I'll be blocking off for the moment, and I'm presuming no permanent damage, need to clean MAF and that's it. I'm lucky I caught it otherwise I'd be replacing a MAF as well. Will probably replace pump and combi valve, or delete if I have the guts...
    Aug 2007
    After researching all night all I've found is a sai pump costs 700 bucks genuine... fml No wonder it gets deleted
    With the MIl lamp code, no harm, but as i always say its best no light incase you end up maskimg any new ones, now thats for the evap, not SAI, just to clarify. However, looks like your Kombi valve for the SAI is stuffed thats wht lets the moisture from the exhaust get into the SAI pump in the first place, fair ive written a fair but about this on this forum. So as i was saying about masking any other codes, you will end up with a SAI flow code as well if that pump stuffs up.
    Only way to get out of the SAI is either replace Kombi valve with gasket and new pump or blank and have the software written to suit. For the P0441 code id be checking the Charcoal canister valve that sits next to the Coolant header tank. Good chance thats the cause of your code
    Jmac
    Alba European
    Mar 2013
    I read your forum post about the issue Jmac, very good stuff, thank you very much
    The code wasnt p0441, it was p0411, very similar!!! It said incorrect airflow detected.
    I guess my picture demonstrates how moisture gets into the system
