This has been exhausted over and over sorry and as Dukezzz says use the search , many discussions and fixes. Google if you may but there is many "experts" there so approach with caution, all that siad there is still real posts there too wont deny that but many incorrect, the joy of the net cant be helped.,but that said here is my slant anyway
if the sai pump is gone the root cause will more than likely be the kombi valve connected to it AND the sai pump. There is no switch on a power steering pump like the other 1.8T family, totally different, not belt driven but elec/hydraulic. Feeling the cam adjuster fault may have been left from the repair perhaps, i suggest save that one and clear it, is the cam chain area noisy cold, seen a couple BJX ( which is your engine code) have cam adjusters go south and it is unfortunately a dear repair, so thats why clear it and see if it comes back. The Sai code will more than likely be linked to the pump being out or very much on its way, caused buy water from exhaust. I would also suggest save the power steering code and clear it too, not common but seen power steer units fail but not so common. Terminal 30 is your main battery input. Have you had any battery or charging issues?. It may have been flagged during a Spike, which maybe something or nothing. The AC code mate is the recirc motor, it can get sticky and reistance in it can flag that code, if thats still working clear it for now
Id take Gav up on hos offer of that pump mate, itll go in a flash , but i would also invest in a kombi and gasket, there may be some guys on here who have a good kombi as some have just removed it to shave the engine bay
Good luck
Jmac
Alba European
