Originally Posted by
sambb
mines always had a funny idle too. rock solid and then will suddenly dip big time. Not in an A/C or ancillaries switching on kind of way - much worse than that. When I pull out my SAI pump I'm going to change the PCV valve and check all the hoses whilst I'm in there. They are a common culprit often apparently.
Mine did that too - it would also run rich as buggery for a few seconds afterward, as it was trying to correct itself. Could never, ever diagnose it. SAI and all that crap deleted, still did it. Changed MAFs, fuel pressure regs, plugs, all sorts. SO frustrating.
Cheap, Fast, Reliable. Choose two.
