Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Rough/hunting idle, coil dying?
  1. #21
    Feb 2014
    Gold Coast, Queensland
    Quote Originally Posted by rgvlee View Post
    My running temps the other day were a bit below normal as well.
    I am fairly sure at the moment my issue is one cylinder.
    Thermostat stuck open? When mine was stuck open it would take forever to get to temp (even summer took longer then it should) and then would drop when cruising in winter. Correct me if I'm wrong but I think the car dumps more fuel in when the car isn't getting to temp, in the attempt to try and get the temp up?
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  2. #22
    Feb 2014
    My Car also used to hesitate/run rough at low speeds, and idle rough when I had an issue with my MAF plug. One of the terminals was to far apart to the MAF sensor pins didn't have a proper connection intermittently and used to get a MAF code because of it. Just another possibility, but again would need a scan to confirm.
  3. #23
    Nov 2012
    WA
    Quote Originally Posted by louis19 View Post
    That would be the the auto choke on warmup
    It's getting up to temp as normal but when running sitting a bit below norm.
    I'll get the exact numbers this weekend when I hookup the data logger.
    No cel/obd codes being thrown
    08 9n3 Polo GTI
    Mods: heaps
  4. #24
    Apr 2014
    Perth
    Just changed my thermostat and coolant temp sensor (I did them for other reasons), still doing it. I'm guessing that it's ignition related since the car sounds like it's running on less than 4 cylinders.
  5. #25
    Nov 2012
    WA
    Finally all my gear has arrived
    VCDS cable took ages even though it was sent express. Doesn't help when the seller sits on it for a few days.
    Will buy the vcds lite and log block 032 what I am I looking for? Just log at idle or go for a drive?
    The 2.0T coils rocked up today
    Will dig out my sai blanking plate and get stuck into it this weekend
    One thing at a time and see if I can isolate the issue
    08 9n3 Polo GTI
    Mods: heaps
  6. #26
    Idle is fine. If the values are more than 10% save them and reset the ecu by clearing the fault codes, even if there aren't any.
    That will zero the trims so you can see if there rocket out of limits. Indicating a leak.
  7. #27
    Jan 2009
    Before buying the lite version, get it all working with the shareware version so you know it's sorted. There is usually some configuration required. On the shareware, it'll still read faults and a few measuring blocks (0-10 if I recall correctly), albeit with very limited information, but you know it works. When you buy the code to unlock, they responded to me within about 24hrs.
    Yell out if you get stuck.
    Daily: 2010 VW Jetta Highline
  8. #28
    Nov 2012
    WA
    So while waiting for the laptop to charge and trial the cable/shareware software I changed the coils out (2.0t coils and ecs bling) and did the crc check on the intake
    It ended up being a stuffed pipe connected to the intake manifold. Must have been getting progressively worse
    All fixed!
    Will still do the other things I was going to do anyway
  9. #29
    All fixed!
    WHich pipe Lee?
  10. #30
    Nov 2012
    WA
    This one
    It's proximity to cylinder 2 probably explains why that plug looked a bit leaner than the others
    08 9n3 Polo GTI
    Mods: heaps
