Results 21 to 30 of 33
Thread: Ross-tech Bleeding Issue 9N3
  1. #21
    Dec 2008
    Sydney/Canberra
    Passenger's side, on the firewall if my memory serves me correct.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #22
    May 2014
    Going to try a gravity bleed. Only thing I haven't attempted. Will keep you posted.
  3. #23
    Adelaide hills, SA
    Quote Originally Posted by Blue Shell View Post
    You most likely wasting your time. The pressure bleed is only the way to force the air out of the VAG ABS system.
  4. #24
    Dec 2008
    Sydney/Canberra
    Yep, and even that can take a while.
    Also, did you scan the whole car for ABS-related fault codes? LIke I said ealier, it only needs to log a sporadic code in somewhere like the CANbus to throw a spanner in the works.
    '01 Beetle 2.0
  5. #25
    I'd be intrigued for you to do mine!
    Cheap, Fast, Reliable. Choose two.
  6. #26
    May 2014
    Wouldn't running the ABS pump bleed that side of it? Well it's free and if it works I'll be about as suprised as I will be stoked.
  7. #27
    Adelaide hills, SA
    No it wouldn't.
  8. #28
    Adelaide hills, SA
    Quote Originally Posted by Stuwey View Post
    I wouldn't spend $2800 for the pressure bleeder if there was other reliable way of changing the brake fluid or bleeding the air out of the brake system. Yes, even changing the brake fluid you have to use the pressure.
  9. #29
    I might be in contact in the not-too-distant future then!
  10. #30
    Adelaide hills, SA
    No worries.
